Screw wont stay in seat
Re: Screw wont stay in seat
The guys are using the drywall anchors you can get at Home Depot. Find one that will push into the hole and screw in your screw. They say they hold great if you get the right size.
Car: 87 IROC-Z
Axle/Gears: 2:73
i am having the same problem but my headrest was recovered and i can't even locate the bottom hole.. the top is the only one i can lacate with my finger. it seems as though the plate with the holes is bent or crooked. the holes are straight up and down right? i will use the anchors if i ever find the holes.
87 iroc z
87 iroc z
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
I'm sure they are straight up and down,if you got the top one in,use it as a template to find the bottom.
If you hold the back of the seat straight up,it looks to be even with the contour of the seat.
Car: 87 IROC-Z
Axle/Gears: 2:73
THANKS, it seems as though i was not following the contour of the seat, so it was not on the right angle. also, I thought the guides pointed forward not back.. (although i dont think it matters)
PS.nice TA, I had a friend with one just like it bird on hood too right?
Engine: 5.0 EFI
Thanks for the comment!!! the seat guides do point to the rear not forward,I think they would get in the way if they were facing forward.Try using a nail or something pointy were you think you found the hole,if you mess up,stick a plastic anchor in the hole with a matching screw(just make sure the guide will cover it)Good Luck
Car: 87 IROC-Z
Axle/Gears: 2:73
GOT THEM ON!! just looked a little harder for the bottom holes. the passenger side tightened right up. I had to use a larger screw on the top of the drivers side but it worked great. it's going to be nice not having the belt flap around!.
the weather is changing for the worse here in michigan so my cruise days are limited!!
Engine: 5.0 EFI
Wonderful way to hang in there and get it fixed like a true blue third genner.
Car: 87 IROC-Z
Axle/Gears: 2:73
Thanks! I just love this website and it's users, This is the 3rd, third gen i've owned but its the only one needing a few touch ups.. everyone is a big help!
I was in high school when i had my other two cars so that was 25 years ago! so glad I can revive my love for these cars!
Engine: 4++,350 & 305 CIs
I take the headrest covers off, either hammer & dolly the holes tighter or weld em up and redrill them, if the screw holes are super loose..
Car: 87 IROC-Z
Axle/Gears: 2:73
I have them on but I pointed them towards the back.. all the pics i've seen of camaros have them pointing forward.. it doesn't look bad and i hate to take them off now. any opinions?
GOT THEM ON!! just looked a little harder for the bottom holes. the passenger side tightened right up. I DVD In-dash Player to use a larger screw on the top of the drivers side but it worked great. it's going to be nice not having the belt flap around!.
