Turn signal lever arm??
Car: 89 Camaro RS (lawn ornament)
Engine: 327 sbc
Transmission: TH350
Axle/Gears: Stock for now
I need a new turn signal lever. I'm pretty sure my car has cruise, but i don't plan on using it with the motor and tranny combo i plan on dropping in it. So my question is, can I just simply swap a non-cruise arm in to replace my cruise arm which is broken at the base? will this one work?? Will it plug right in? The non-cruise ones are alot cheaper anyhow.
http://www.ebay.com/itm/Dorman-Turn-...36c95c&vxp=mtr
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Turn signal lever arm??
You can use that!!!the only thing that plugs in is the cruise control wire that comes with the turn signal lever.
Former Sponsor
We carry them on our site with free shipping. Here's a link to them if you would like to check them out.
Camaro Turn Signal lever
Prodigious
11-07-2020 09:23 AM
Fronzizzle
03-18-2019 08:29 PM
