Rear defrost metal tab cracked
Old 05-21-2012 | 11:52 AM
89 350's Avatar
Car: 1989 formula
Engine: 350 l98
Transmission: 700R-4
Axle/Gears: 327
I have an 89 formula and the metal tab that connects to the bottom of the glass on the hatch which i assume is for rear defrost cracked in half how can i fix it can i just solder back together of some type of adhesive thanks part is still attached to the window why the other half is still connected to the wire
Old 05-21-2012 | 09:15 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Rear defrost metal tab cracked
I'm sure the only way to fix it would be to solder it,if it's the piece I'm thinking it is,it's copper so that can be soldered.
Old 05-22-2012 | 12:22 PM
89 350's Avatar
Car: 1989 formula
Engine: 350 l98
Axle/Gears: 327
great thanks will give that a try
Frozer!!!
01-19-2024 05:55 PM
crt454
Interior Parts Wanted
06-23-2017 03:25 PM
AkDrifted
08-17-2015 08:45 PM
kitt23
Exterior Parts Wanted
08-15-2015 01:37 PM
3rdgenparts
Exterior Parts for Sale
08-08-2015 12:48 PM
Quick Reply: Rear defrost metal tab cracked
