I always smell like exhaust after a cruise.
Car: 1989 Camaro
Engine: Sbc 355
Transmission: TH350
Axle/Gears: 3.42 Detroit locker
I have sealed all wholes in firewall and the spot under shifter (since mine used to be a manual car). Looking to get any other suggestions so that after I go for a cruise I wont smell like exhaust! Where else to seal that im not thinking of, what else to do ..
Car: 1989 Camaro
Engine: Sbc 355
Transmission: TH350
Re: I always smell like exhaust after a cruise.
whats a good way to check for leaky headers. I dont hear any ticking from them or anything like that.
Car: 1989 Camaro
Engine: Sbc 355
Transmission: TH350
yea its right under the car around where the ujoint and rear axle is. moving it to rear and outside would make that much difference? like to have it not showing.
and wanted to stay away from going over the rear axle, any other suggestion to routing
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Car: 1989 Camaro
Engine: Sbc 355
Transmission: TH350
I almost did the side pipes, but ran out of scrap pieces to make it. Also got tired of laying on back on and off the car to weld. lol.
Car: 1989 Camaro
Engine: Sbc 355
Transmission: TH350
I actually have an open breather off the valve covers.. that ok?
Car: 1987 IROC-Z
Engine: 5.7L
Perhaps you have an exhaust leak by your headers, and that which is leaking, is sneaking into the holes where the Heater Core goes through the firewall, then the air from ac/heater is pushing that exhaust leak into the vents, and onto you.
Car: 1989 Camaro
Engine: Sbc 355
Transmission: TH350
Will have to continue to track that down. Hoping to find it soon. Thanks
Car: '89 Camaro RS
Axle/Gears: 3.42, Open
I bet if you had some sort of tailpipes sticking out from under the car it would take care of it, i had the same problem with an old car i had a couple years ago, the exhuast turned down at the rear end on it too, i finally broke down and put some tail pipes on it and it took care of it.
Glowsock
09-11-2015 11:09 PM
