1988 Camaro STEERING COLUMN HELP PLEASE
Car: 1988 Camaro IROC-Z28
Engine: 305 V8
Transmission: Automatic
Axle/Gears: Posi
Ok, so my column is all loose and I pulled the column apart. I tried tightening the 3 torx head bolts. That didnt do it. So went further. The roll pins are tight in there. THATS when I found the two bolts behind the tilt? I think its ethier the tilt assembly or somthing right behind it....anyways, I have to tighten those two weird looking bolts and I should be (crossing my fingers) alllset.
But, I need to take out the roll pins and I dont have the "special tool" to take them out with and Advanced Auto Part guys looked at me like I had two heads when I was trying to explain to those (no offense) BONEHEADS what I needed.
Can anyone help me by giving me the name of that tool and where I could possibly find it? I need this ASAP PLEAAAASSSSEEEE![help](https://www.thirdgen.org/forums/images/smilies/help.gif)
Thanks!
![Confused](https://www.thirdgen.org/forums/images/smilies/confused.gif)
Thanks!
![hmmm](https://www.thirdgen.org/forums/images/smilies/hmmmm.gif)
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: Restored 88 GTA
Engine: 5.0
Axle/Gears: Posi
Re: 1988 Camaro STEERING COLUMN HELP PLEASE
Have an 88 GTA column for sale, go over to interior parts for sale,,,,,,,,,,,
1 Post
Car: 1988 iroc
Engine: 350 30 over
Axle/Gears: Series 2 373
Yes when you pull the wheel off and then remove the 3 screws of the blinker electric you will see the bearing assembly
Engine: 305 V8
Axle/Gears: Posi
And I still need the tool name for the pins....
Engine: 5.0
Axle/Gears: Posi
https://www.thirdgen.org/forums/inte...mns-cheap.html
For $50 shipped to your door. You will have to reuse your turn signal switch and cancel cam.
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
According to this article I beleave they are calling it a "Pivot pin removal tool" .Read through the article and decide for yourself.
= http://www.ehow.com/how_5890372_disa...lt-column.html
Engine: TBI,5.0
Engine: 305 V8
Axle/Gears: Posi
Thanks guys. im just gonna swap in a new column. its dead
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Why would you spend the money on a column (plus shipping, plus wait time where you can't drive) when you can have the thing fixed in a couple hours? The 4 External Torx bolts that are way under the tilt assembly are the ones that come loose and screw up the whole works. You can only see 2 now, but there are 2 more up top. Pull the pins out of the tilt mechanism and the others are visible... Use locking compound on all 4 and never worry about them again.
The worst parts about the reassembly are getting the tilt spring back in again, lining up the headlight dimmer switch lever parts, and keeping the upper bearing parts in place while putting the lock plate on (if the upper bearing retainer isn't fully in position, you WILL bend the lock plate... ask how I know
Good thing it was my old junk column!).
ron, thanks for the link. I can't tell you how many plain jane screws I've broken prying against them with pliers to get the pins out... I've gotten lucky a couple times using the screw that holds the lock pin spring in place, but I don't want to push my luck again
![doh](https://www.thirdgen.org/forums/images/smilies/doh.gif)
![EEK!](https://www.thirdgen.org/forums/images/smilies/eek.gif)
evilstuie
02-28-2016 03:33 PM
