Alternative to dynamat?
Old 03-09-2012 | 11:38 PM
86_irocz-28's Avatar
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
doing a resto on my 86 and want to put sound deadner in is there anything like dynamat that is cheaper?
Old 03-10-2012 | 02:24 AM
inkedbass's Avatar
Re: Alternative to dynamat?
Second skin, Alpha Damp, Fat Mat, Brown Bread, the list goes on and on.
J
Old 03-11-2012 | 06:29 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
Found this link in another thread, and just ordered some.
I can't testify to any results yet, but I certainly like the characteristics:
aluminum skinned thin foam (very light-weight, and heat reflective),
and economical. good bang for the buck.
http://www.lobucrod.com/
(And quick processing for delivery.)
Good luck, and keep us posted.
Old 03-11-2012 | 09:21 PM
jpgreen10494's Avatar
Car: 90 Firebird, 96 caprice 9c1
Engine: 305tbi, lt1
Transmission: 700R4, 4l60e
Axle/Gears: 2.73, 3.08
Eastwood sells there own brand, not bad cost wise. My brother has it installed in his truck, it does a great job
Old 03-12-2012 | 03:31 AM
Swigbeast's Avatar
I just tore my car apart to put some sound deadener in as well as EZ Cool heat insulation. My deadener is Peel N seal from Lowe's, I've heard good and bad about it, but if you dont want to pay hundreds, it should do the job.
Ill be putting that down with aluminum foil around the edges
Peel n Seal $18/ 12.5 sqr ft.
EZ Cool $32/ 40 sqr ft.
We'll see how it goes, I've been doing hours of research and this is what I've decided on for the price I dnt see how I can do better.
Old 03-13-2012 | 08:34 PM
For what it's worth...
I'm finishing up insulating the interior, and 1 roll (4'x10')
of the EZ Cool is not quite enough to do all the floor & roof
area. Two rolls should provide enough to include something
on the doors. Since the bird is still a good way from serviceable,
I can't provide any before/after testimonial, but installation was
really easy, and it seems like ... well, ditto what I said before.
Old 03-13-2012 | 08:46 PM
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
anybody used thermal block or something like it and i know it says Apply on the engine side fo the firewall for the ultimate in pre-cabin heat treatment but can i use it inside the car on the firewall and have the same effect?
Old 03-13-2012 | 09:13 PM
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Looks like ill be going with eastwood or EZ cool let me know how it works
Old 03-14-2012 | 12:58 AM
Swigbeast's Avatar
I've heard the same thing about a variety of heat insulations, when theres some air between the heat source and the foil, its supposed to work better.
I think its because if the firewall is already hot, and its glued or whatever to the ez cool, then the heat will be transferred much quicker by just being in contact with the hot metal.
If this makes a big difference, I'd like to find a way to get the best results without putting it in my engine compartment. That just doesnt look very good
RS Reaper
10-17-2018 08:52 PM
apie2546
10-16-2016 03:24 PM
SRKLEGIN
10-03-2015 11:11 PM
RS Reaper
09-27-2015 08:04 PM
raymondandretti
09-27-2015 07:43 PM
