Malfunctioning Gauges
Car: 1988 IROC-Z
Transmission: Automatic
Hey there,
I just joined the sight seems to have a lot of useful information.
I bought myself an 88 iroc with the l98 and im having some problems with my guages. my temp guage is completely useless and im wondering if the guage itself is done or if its just the sending unit. My speedo also seems to be way off and jumps wildly if I mash the pedal.
Any input would be greatly appeciated.
thanks
Zach
thanks
Zach
Re: Malfunctioning Gauges
Car: 1988 Iroc-Z
Engine: 350 TPI; Stock internals
Transmission: 700r4; TCI-CPVB; BW Hi-Frition
Axle/Gears: 4th gen 7.5 w/ 3:42 gear
The gauges are notoriously wrong in these cars bro... As for the speed-o, its prolly your speed-o gear in the rear of the tranny... Also would be the speed-o gear ring on the output shaft... you can see both if you'll pull the housing out and have a look w/ a flashlight...
Doc
Doc
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Hey there,
thanks
Zach
thanks
Zach
Car: 08 mega cab ctd 86 irocz
Engine: 355 Carb
Transmission: 700t4-th350
Hey guys I been browsing the site I'm new here also. Bought an 87 irocz just a project car. It was salvaged the wiring is all hacked up with wire nuts every where and random wires knitted in weird places I'm putting a Carb motor in it and just pulling wiring out. I wrecked my stock speedometers cable to in pulling motor and transfer. IV seen some cool auto meter gauges installed in the dash. They way I'm reading someone sells a kit to put gauges in the dash rather fabing up my own gauge cluster but have had no luck finding anything some point me in right direction
