Recaro seat rails
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Recaro seat rails
I recently picked up a pair of Recaro LS's from a '91 VW GTi. I'm having a hard time trying to find the correct seat rails to fit my car. Were they supplied from GM or from Recaro? Where can I find a set? I'd prefer to buy the correct sliders rather than trying to adapt my factory rails to the seats, but if comes down to that being my only option then I'd like to see what people have done to get Recaro's to fit.
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Recaro seat rails
I would think you would have to use your factory rails to match the factory bolt holes on the floor.
Car: 85 Z28
Engine: 327
There is a recaro guy out of Everett who is on this forum. Ill see if I can track down his number.
Engine: 4++,350 & 305 CIs
I have Recaros in on of my cars and they use a recaro bracket that bolts to the factory sliders.
They kind of make the seats sit a bit higher...
Engine: LB9, LB9
Yeah, but the factory rails don't bolt up directly to the Recaro's. See all Recaro's have the same mounting holes in their bases, no matter what vehicle they were installed in. Only the rails differed for the application.
Engine: LB9, LB9
Do you by any chance have any pictures of the adapter brackets?
jerflash
09-24-2015 03:11 PM
