Window making a knocking noise
Car: 1992 RS
Okay, it started sunday night. Hit the switch to roll the window down, and all it does is knock... Push it down while holding the switch and itll go down. When u stop pushing it, it does to and starts knocking. Roll it up, and it goes up perfectly fine. Until tonight. When it started banging real loud. It went up, almost to the top and started making that noise. We got it to go all the way up. No idea what it is... Help! =}
Car: 1992 RS
Re: Window making a knocking noise
Oh! Something else!! While holding the switch to go down, with it about half way down, u can pull the window straight up with no trouble. Motors only a few months old, too
Car: 1992 RS
Thanks! Ima go to oreilly n get them to order a new one, try it again! Haha. Do u know of any way to tell if somethigs wrong with the regulator?
Car: 92 RS
Axle/Gears: 3.08
Hey if you go to orielly make sure you are getting a new one. If not they will give you a reman they are 42.99 the new one is 49.99. But the cool thing is you can make them price match the new one with advance auto for 31.99. I know this cause I had to do this the other day. hope this helps
theshackle
09-17-2020 08:26 AM
db057
08-11-2015 10:11 PM
