rear window defogger
Old 12-30-2011 | 01:25 PM
dholtrey's Avatar
Car: 1984 Z28
Engine: late 70's 350 4bbl Holley
The rear hatch defogger on my '84 wouldn't work, and whenever I would push the defogger switch, my gauges would go nuts, and the indicator light on the switch wouldn't stay on. Replaced the switch/delay module, and still the same problem. Happened to notice that when the hatch was up, the switch's indicator light worked. Turns out that the wire that feeds voltage to the defogger (left side of the closer) was almost completely disintegrated, probably from age. Unplugged it, cut it, cleaned it, tinned what was left with solder, and soldered in a piece of 12-gauge stranded wire. Removed the insulation from the new wire so it would be more flexible when the hatch raises. Now it works just fine. Was a real problem to track down, but maybe the information will help someone else.
Old 12-30-2011 | 01:44 PM
Hal87's Avatar
Car: '84 Firebird TA & '87 Camaro LT
Engine: 350 V-8 & V-6
Axle/Gears: 3.23 & 3.42
Re: rear window defogger
Welcome to the forum and thanks for sharing!
1992 Trans Am
05-10-2023 08:19 PM
Vintageracer
01-10-2020 06:33 PM
colton_carlson
03-08-2019 01:21 PM
69 Six Pack
10-05-2015 08:51 PM
Dialed_In
08-20-2015 02:45 PM
Quick Reply: rear window defogger
