Consensus On Dash Pads
#101
Car: 85z28(sold),91 rs, 15'Mazda3GT
Engine: 5.7L V8 350 (ZZ4)
Transmission: 700r4 rebuilt with kits+ vette serv
Re: Consensus On Dash Pads
I found a dash pad with a small crack (smaller than a penny) from a junkyard for $20 and rest of it no cracks, how much you think it's worth if I were to sell it, its perfect condition except the really small crack in corner on driver side.
#102
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
It all depends on who wants to spend money on a already damaged item,maybe somebody that wants a project.I don't think your going to get much more of what you paid for it,because their is going to be shipping involved also at about $50 $70.
#103
So.........A number would be nice, and no need to remind me it's "already damaged", I just said that
#104
Engine: 5.0 EFI
here are some pics of the dash cover,it's so easy,first step clean with an ammonia solution,I used Windex
#105
Engine: 5.0 EFI
second,run the adhesive(supplied w/cover)around the all the edges and around all the openings(speakers,defrost vents,air condition vents)
#107
Engine: 5.0 EFI
Third,place the cover on the pad and place something with a little weight so it will adhere to the pad,then let it sit overnight or at least 8 hours .It has to be at least 60 degrees,in my case it was in a garage with the heat on 70.
#108
Engine: 5.0 EFI
And this is what you get,Total time about 25 minutes.
#112
Car: 1991 Camaro Z28
Engine: 5.7L
Now you're cooking!
I'm really curious about the front edge and even under the front edge. Does it wrap completely around it and do you glue underneath?
#113
Engine: 5.0 EFI
I only ran adhesive along the edges on top,the fit is real tight and the front lip wraps tight underneath,very snug.
#114
Engine: 5.7L
It looks decent enough...
I sure appreciate your pictures and hope some of the others who recently purchased will share their experiences too. I'm a bit away from needing to purchase my replacement but have been looking at the entire pad from hawks.
#115
Car: 91 Formula Firebird
Engine: 5.7 TPI
#116
Engine: 5.0 EFI
Same here,I was going to get a GM Restoration Part Dash Pad from Classic but their no stocked and will have them hopefully soon.
#119
Car: 02wrx/88 rs
Engine: 2.0L turbo/nothing yet!
Transmission: 4eat/waiting on a t56
x2 for the dash carpet. i have one and i like it. easier to keep clean too
#120
Engine: 5.0 EFI
That was the only one offered,82-92.That's all they list.
#123
Engine: 5.0 EFI
That should make your dash last longer,looks good.
#124
Car: 02wrx/88 rs
my old dash had velcro strips attached to it and there is no getting it(velcro) off the dash, however with the new 3m strips, im sure there is another way even if not, two small strips when you take it off are not bad. better than the cracks
#125
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
I have an 89 IROC without any cracks on the dash. I have a dash cover from Dashmat which I remove and clean my dash and then cover with Pledge about every 3 months. The Pledge keeps it supple and the dash cover keeps the sun off the dash.
http://www.dashmat.com/
F.Y.I., I found a dash pad with no cracks for sale down here in Fort Worth, TX on Craigslist. Not sure of the color but if you need one for 75 bucks here it is.
http://dallas.craigslist.org/ftw/pts/2721358040.html
I hope this helps someone.
#126
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
My dash from Rick's Camaro came in on friday. it looks great, the cell pattern is identical to the stock one.
Only gripe i have, is there are not screw holes in the cap for the front mounting to the firewall. Im going to drill those holes so if i ever need to remove the dash in the future, i can.
I'll take some pictures today of how it looks out of the box and covered on the original.
#127
Engine: 5.0 EFI
I didn't have any issues with the screw holes,are you installing the cap out of the car or in it.
#128
Engine: 4.3 Turbo
Transmission: 4L60
problem.. if you do, the cap will cover the screws, and if you used the glue/bonding agent near the edges like it says to, you will glue the cap over the screws, making it very hard to ever remove the dash, should you ever need to. Like if you need to get to your speakers or vents..
which is why i will drill the hole for the screws, that way i can glue around them, and remove the dash without issue in the future.
#129
Engine: 5.0 EFI
That would be a good idea,you shouldn't have to do that,they say it fits right in yah right!!
#130
Car: 90 camaro iroc-z
Engine: 5.7 tune port
Transmission: auto (for now)
hey, has anyone tried one of the fiberglass dashes from thirdgen ranch?
How did it look and how close to stock?
#131
For the carpeted dash cover, they just stick down with some Velcro strips, but I didn't use them, I just layed it up there and it hasn't moved.
#132
Engine: 5.0 EFI
It bothers me too,but that crack bothered me more.I can live this until the end of this coming summer and maybe Classic will have the OER in stock. Hopefully they might have them before summer,then I can swap this out and sell it.I'm saving the huge box and packing this came with.
#137
Car: 1988 Camaro IROC-Z28
Engine: 305 V8
Transmission: Automatic
Axle/Gears: Posi
i was thinking....dont think im destroying the original car, its just a thought.....how about wrapping the pad in leather? like professionally. I was thinking black leather with red stitching......i want to get black leather seats with suade in the middle (so i dont go flying around the car on coners) with red stitching......
#138
Engine: 5.0 EFI
Ain't that nuts,but then again it's not 20 something years old,it's new,fresh.You could spend that kind of money on constantly replacing these old dried out ones that cost at least on average a couple hundred $$$ w/shipping and crack on you within a year,It don't take much to crack the old ones. Believe me I know(I'm on my 3rd)
I'm ordering one when the TA dash pad becomes available.
#140
Engine: 5.0 EFI
#143
Engine: 5.0 EFI
SHHHHH,The 85 might hear you.Don't jinx it.
#144
Car: 86 firebird t/a
Transmission: auto
Axle/Gears: stock
im sure this may have been covered but not sure will a camaro dash pad fit in a t/a?
#146
Transmission: auto
Axle/Gears: stock
ok cause when i got the bird i got an extra dash pad and i think its for a camaro i havent looked to closely at it
#148
Engine: 4.3 Turbo
Transmission: 4L60
ok i finished the cap install.. its currently curing at the moment, i did it with the dash pad removed. going to make my own thread on how to do it, pretty easy really.
#149
Transmission: auto
Axle/Gears: stock
if i can get enough light on it i will lighting in my garage sucks
