ABS headliner came as a flat unshapen piece?
Alright so I picked up a abs headliner today and its just a flat piece of plastic?
I was under the impression that it would be somewhat shaped and contoured?
Are they all like this?
How do I install it?
![huh](https://www.thirdgen.org/forums/images/smilies/huh.gif)
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
Re: ABS headliner came as a flat unshapen piece?
first...take it out of box and let it sit out on a flat surface for it to regain all of its shape
second...they are very flexible when you put it in the car it will contour to the car once all the parts are installed around it
third... you install it starting with lining up the sun visor holes and work your way back
Picture?
Anybody? It just looks like someone cut out the outline of a ttop headliner. I thought these where supposed to come somewhat moulded in the shape of the original headliner?
Don't have my digital camera atm Its a completely flat piece of abs in the shape of a t top headliner with the holes for the sunvisors and no other markings. I want to know if this is how they all are or if this is something the guy at the shop I bought it from made.
Where'd you get it?
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
they usually come folded in half, but defiantly not totally flat, not by a long shot. if what you have is a perfectly flat piece, send it back and buy one elsewhere, its not right and/or sombody is trying to rip you off
The sad thing is I was planning on ordering a couple thousand dollars worth of parts through him after this as opposed to online. Not happy with the entire situation at all.
call and ask questions
As Scott said, ACME is the maker here, IDK about up in the Great Whie North.
Sounds like they may have lost a good customer!!
Get ahold of CamaroSource, a member on TGO somewhere in Canada, maybe he can point you in the right direction???
Hope its just a misunderstanding.
dbrochard
09-19-2015 08:13 PM
1Aauto
Sponsored Vendors
09-02-2015 01:35 PM
