power window help
Car: 1982 trans am
Transmission: 4 speed
Axle/Gears: 3.08
power window help
I have a 1991 firebird and doors off a car that im not sure of the year, what i need to know is if the plug on the motors is the same throught the years. ive been trying to connect the motors for a while now, they look the same, but for some reason i cannot hook them up.
Car: 1987 Trans Am
Engine: LQ9/L92
Re: power window help
GM used the same motors for many years across many different vehicles - you should have no issue swapping with other 3rd gens. make sure you don't have any pins stuck in the connector or any bent contacts that may be getting in the way
1992 Trans Am
05-10-2023 07:19 PM
IROCZDAVE (88-L98)
09-13-2015 09:07 PM
