Steering colum very loose!!!
Old 03-28-2011 | 01:30 PM
89firebirdUSMC's Avatar
Transmission: 350r
i have an 89 firebird,
the steering colum is verry lose and i can move it an a complete circle, up down, side to side. i even have to push the colum to the left to engage my highbeams. im clue less but i herd there is 3 or 4 bolts in the middle of the colum that get loose sometimes. but i dont wanna gut the steering colum and there be no bolts, or there be a simpler fix, any help would be appretiated, thank you
Old 03-28-2011 | 01:50 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Re: Steering colum very loose!!!
heres a write up on it
https://www.thirdgen.org/steeringcolumn
Old 03-29-2011 | 08:57 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
If it's just your steering column it would be the four bolts.Take down the panel under the steering wheel and you'll see four brass colored bolts and just tighten them up.But if it's the steering wheel that's a hole new ball game.It is easier to just put in a new column.
Old 03-30-2011 | 12:01 AM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Easier, but not cheaper! Thats a good write-up.
Old 03-30-2011 | 12:19 AM
coryprine's Avatar
Car: 85 Camaro Z28
Engine: 5.7 TPI
this is a verrrry common issue with the camaros and firebirds.... fairly easy to fix though....
Old 03-30-2011 | 02:57 PM
mantaguy's Avatar
Engine: 5.0 EFI
He can pick one up on here TGO,RED88TAGTA has one for $75,that's not bad considering if the steering wheel is messed up,I don't know about you but it's a bit meticulous for me.
Old 03-31-2011 | 06:05 PM
steven72192's Avatar
i tightened those 4 brass bolts and still nothing i can still move the steering wheel in a cricle any other sugestions?
Old 03-31-2011 | 09:11 PM
mantaguy's Avatar
Engine: 5.0 EFI
I had the same problem,I put another steering column and wheel in,It looks harder than it really is.4 bolts under the dash,3 bolts on the fire wall under the dash,2 bolts under the hood.Or you can have a mechanic fix the wheel.
Old 04-01-2011 | 10:41 AM
so that is how to install a new one? and do u think if i tightened those bolts u listed it would tighten it up?
Old 04-01-2011 | 12:19 PM
mantaguy's Avatar
Engine: 5.0 EFI
No! it's your steering wheel-and it would be a real pain to rebuild it yourself.If I were you and you don't know how to do this, I would definitely have it done by the pros.Even if it cost you $100 or so,it would be done the right way.
Old 04-01-2011 | 12:26 PM
ROCFATHER's Avatar
Car: 89 IROC-VERT
Engine: TPI 305
Transmission: 700R4 Auto
Axle/Gears: 2.77
I almost didn't buy my ride because of this, until I found out its pretty common. I started to repair it myself but its quite a task! There are layers of things to remove just to get to the darn screws. If you have lots of time and the patience then go for it if not take it to a shop. I think I paid like 180 out the door plus they installed my Grant steering wheel. It was well worth the headache!
Old 04-01-2011 | 12:36 PM
mantaguy's Avatar
Engine: 5.0 EFI
That's not bad considering the column is going to cost $75 or better and 2-3 hrs.of labor.Especially if you don't know how to do it.
Old 04-01-2011 | 01:21 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
I dropped my car off a few years ago for the same problem. 6 hrs & $100 later at a local mechanic and it was solid as a rock. Has been ever since, but I also know what causes it. Using the steering wheel as support to get in & out of the car.
Mine was solid when I bought the car, got looser & looser after buying it within 2 yrs. Got it fixed & hasn't budged since, since I also no longer use it to get in & out.
Old 10-03-2011 | 01:12 PM
tphillippi2's Avatar
Car: 85 Z28
Engine: 358ci Small block
Transmission: Th350
Axle/Gears: factory 3.23
mine does the same thing. i havent tried to tighten the screws but the guy who had the car before said that they had a bellcrank rigged up in it instead of using the hydralic clutch. i guess it was so hard to push he bent the seat and made the column so loose that you have to push it to the left to switch from high to low beam. i was just going to get a new column but id like to take the cheapest way out.im a little low on money lol
Old 10-03-2011 | 06:58 PM
one92rs's Avatar
Car: SOLD!!!!!
i need to do this myself but just havent done it yet. mine is only slightly loose.
Old 10-13-2011 | 12:53 AM
thekingGAMBOA's Avatar
Car: 1989 Camaro z28
Engine: 305 tpi, stock
Transmission: 700r4 vette servo, shift kit
I tightened my column and now that is perfectly snug, but I was not able to tighten the wheel it still jiggles and wiggles but the wheel is on screwed to the hub fine. I believe it may be the bearing? any suggestions?
Ed1LE
09-30-2018 10:14 AM
loud91rs
10-05-2015 11:05 PM
sjorgens
10-01-2015 08:54 PM
HoosierinWA
Members Camaros
09-29-2015 01:43 PM
Night rider327
09-25-2015 05:19 AM
