86 camaro defogger?
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
86 camaro defogger?
My 86 has grid lines at the very top of my hatch, near the third brake light and i have wires running to my hatch, near the shocks. my question is, does my car have a defogger or defroster? if so how to i turn it on?!?! im having problems with my rear glass fogging up so bad that i cant see out of it!
Car: 85 Z28
Re: 86 camaro defogger?
The defroster wires run across most of the rear hatch of my 85, not just at the top. The factory switch for the rear defrost is on a little panel just below the cigarette lighter. The switch has a little orange light that comes on when the defroster is on and a timer built into it shuts it off after about 10 minutes.
Engine: L31 350
mine are only around the top of the glass near the third brake light but i dont have that switch near the lighter. anyone else wanna input?
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
It sounds unusual to me. Someone may have swapped the rear hatch if none of the wiring or switch are there. If you don't have the switch then it most likely didn't come with a rear defroster. One way to double check is to look under the drivers side door sill or under the carpet behind or in front of it for a large purple wire.
For the time being you can try Rain-X Fog on the inside of the glass.
Engine: L31 350
i have all the wireing ( plugs coming off the hatch) and i have the lines but like i said they are only near the top around the light, which is why i think its a de fogger i just dont know how to turn it on
Engine: L31 350
oh, i thought defrosters went all te way down the glass and de foggers were only half way down?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If you live in a cold climate, it'll be called a defroster. If you live in a humid one, it's a defogger. It's the same thing either way.
Kind of like the way up north it's "antifreeze" but in the south it's "coolant".
Engine: L31 350
guess its a fefroster for me , im in indiana and its currently 27 out and we have antifreeze lol
84z96L31vortec
08-20-2017 12:16 AM
