HOW do i fix the speedo. rpm gauge etc.????
Car: 89RS-5.0/88IROC-Z-5.0/92-5.7 z28/v6
Engine: 5.0/5.7/2.8
Transmission: 5 spd in two stock auto in other tw
Axle/Gears: stock
the rpm gauge on all of OUR 4 camaro's are shot!! most of the speedometers are shot too!!!
JUST WONDERING IF THERE'S A WAY TO RESET/FIX THESE GAUGE'S???
Re: HOW do i fix the speedo. rpm gauge etc.????
Engine: 5.0/5.7/2.8
Axle/Gears: stock
does that include the rpm gauges too?
1 Post
Car: 92 RS
Engine: a slow one
Transmission: a crunchy one
Axle/Gears: a whiny one
No, the tachometer is a totally different issue, usually requiring you to replace and re-solder some resistors and connections on the back of the cluster.
Car: 91 Z28 / 04 GTO
Engine: GMPP 350 TPI / LS1
Transmission: WC T5 / T56
Axle/Gears: 3.23 / 3.46
If the gauges have ever been removed they were probably not set back in far enough. For me simply removing the whole cluster and seating it properly fixed my tach and speedo. It's worth the 5 minutes.
theshackle
09-17-2020 08:26 AM
86IROC112
08-17-2015 02:00 PM
