How to wire a 6 pin fourth gen seat?
1 Post
Car: 91 RS T-top
Engine: 305 tbi
Axle/Gears: 3:42 fourth gen disk brake
My fourth gen seat has six wires not 2. Has anyone wired one of
these? Thanks
these? Thanks
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: How to wire a 6 pin fourth gen seat?
Might try signing in and asking on the LS1Tech.com site. Someone there is bound to have wiring diags for that seat.
Im pretty sure the seats still get a power and a ground. It might get two powers...I cant remember off the top of my head.
But those 6 wires go from one seat to the other. Both seats are powered from the driver's side. The 6 wires go from the driver seat to the passenger seat to tell the air pump that you want to inflate/deflate the lumbar/side bolsters in the drivers seat.
Here's a diagram for I think a 99...
Another...
Basically..just give power and ground to the one side of the harness, and the harness will take the power over to the passenger seat as well as power the drivers seat.
Do you have the jump harness that goes from seat to seat with the wires and hoses???
J.
Another...
J.
1 Post
Car: 91 RS T-top
Engine: 305 tbi
Not noticing any but will pull the cover off the other seat. Thanks both of you. Im sure ill get it.
There's a harness with the air hose that connects the two seats, and two of the wires onthat harness connect to power and ground on the car. Basically the drivers seat does all the work, the passengers side just slaves off of the drivers.
eightsixseven
08-14-2015 03:09 PM
1992 Trans Am
08-08-2015 08:16 PM
