Cooling interior ?
Car: 1991 camaro Z28
Engine: 5.7 350 TPI with a performance chip
Cooling interior ?
I have a sun reflector for the front window of my third gen, but it still gets hotter than blue blazes! I was wondering is there a similar type made for the hatch or am I just barking at the moon?
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: Cooling interior ?
Ive never seen one, but you can always make something yourself.
Car: 91 Camaro RS
And its not just the glass letting in light that makes things hot. The color of the car has a huge impact on how it retains heat. The darker the car, the worse it is.
Thanks, I do crack the windows a lot! I have a system to how you I put them haha. My car is the Dark Red Metallic so i'm screwed on the color. I am thinking about just "macgyvering" something together.
Car: 1985 Camaro Z28
Engine: 305 mild build up
Axle/Gears: Stock
I once saw a little battery powered fan that can be hung on the window that helps move air in the car when you have it parked. Of course the windows need to be cracked a little. and I remember that it took like 2 aa batteries, and could last almost 2 weeks per battery change. It was supposed to lower inside temps by 30% or more. But it has been years and I dont even remember who made it. But I am sure it can be found or home made. I know down here in Texas we need them for sure.
Car: '88 Camaro (Gone...)
No one has mentioned louvers yet? They sure work
Of course, they're ridiculously expensive and you have to like the style But they work really well
Car: 1991 Firebird
Engine: 383 stroker
I wouldn't go too dark on the window tint. I can't speak from experience, but I've heard that if you go too dark, it can actually start holding the heat. Not a whole lot different then dark paint I guess. Even though it doesn't allow the light into the car, it can make the glass super hot I think.
And I'm kinda in the same boat, trying to keep the interior as cool and efficient as possible. One thing I'm gonna do is pull down my headliner, and see about putting down some sort of insulating material. A guy I work with told me to check out home depot cause they carry a few types of materials that might install to the headliner fairly easily.
Car: camaro84.87iroc,91vert
Engine: Lt1, 383tpi,350tbi
Transmission: t56,T5,T5
Axle/Gears: 4thgenunknown,373,323?
tint doesnt have to be dark to prevent heat cause by the big ball of gases in the sky...ive seen tint that was only 50% but was rated up there with 20%..its a little expensive though..its made by johnson or llumar..cant remember which..but its real thick...and no it wont be like a magnifying glass..thats what you got now
1 Post
Car: 1989 Formula 350 / 2001 TA WS6
Engine: 350 / LS1
Transmission: Auto / Auto
my formula is black with black interior. it can get really hot. i try to park in the shade as much as possible when i have it out. but its not a daily driver and spends most of the time in the garage.
IROCZDAVE (88-L98)
09-02-2015 08:49 AM
IROCZDAVE (88-L98)
09-02-2015 08:43 AM
