How do i get my center console out ?
Old 05-07-2010 | 09:08 PM
rs91white's Avatar
I need some help with my 91 5 speed center console. I have all the screws out but i need to get the Emergency brake in the straight up postion to lift the console out . Is there something i can do to the e brake from the inside to get it in that postion ?
Old 05-07-2010 | 09:24 PM
juanillox8's Avatar
Car: TOO MANY
Engine: 350 TPI / 350 TBI/6.0L VORTEC
Transmission: T5/AUTO/AUTO
Re: How do i get my center console out ?
there's 2 or 3 10mm bolts holding the e-brake down u need to take them off
Old 05-07-2010 | 11:33 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
You dont need to get the ebrake straight up. Just pull it up as far as it will go then lift the back of the console up first till the ebrake is clear. Atleast thats how Ive always done it.
Old 05-08-2010 | 12:48 AM
91zconvt's Avatar
Car: 87 Iroc
I second this. I've never had to remove the e-brake. ESPECIALLY not with a 5 speed. Much easy to maneuver around that then the auto shifter. You do however need to take the leather wrapped handle off the e-brake. Should be one small Philips screw holding it on.
Old 05-08-2010 | 11:56 PM
1990z28's Avatar
Car: 1990 Z28 Camaro
I got a 90 with a 5 speed i just pull the four bolts that hold it to the floor after pulling the shifter panel and all that. and I never have had to pull off the handle on the shifter only thing is watch out for the plastic breaking from age but its simple just pull back as far as you can get it and lift back and slip handle threw the hole.
Old 05-09-2010 | 12:54 AM
91zconvt's Avatar
Car: 87 Iroc
I'm pretty sure that even with a 5 speed, you definitely have to pull the shift ****. Unless you know a super special way to get the boot above said handle...
Old 05-09-2010 | 02:16 PM
1990z28's Avatar
Haha next time i should proof read I meant the E brake handle not the shifter my bad on that one.
Ed1LE
09-30-2018 10:14 AM
Lbibb
05-05-2016 01:00 AM
BrianChevy
Wheels and Tires
10-13-2015 01:33 PM
TheCardinal
Exterior Parts for Sale
10-01-2015 08:40 PM
ndndndnd
09-28-2015 09:00 AM
