Rear speaker enclosures
Car: 1992 Chevrolet Camaro RS
Engine: 3.1 Litre V-6
Transmission: Automatic
While going through the various '82-'92 Camaro and Firebirds at the local wreckers, I've seen rear speaker enclosures on some of the cars. My car ("92 RS) is heavily optioned but does not have these. What's the deal? Did they come with a paticular sound option? Seems like they're more often on Pontiacs.
Last edited by Brandon J. Watt; 04-16-2010 at 04:41 PM. Reason: Grammarical correction
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
Re: Rear speaker enclosures
to my knowledge...only 4th gens had speakers installed stock into the trunk area..may be wrong tho
The speakers aren't in the trunk. They are the standard locations next to the rear seats but some have a "soundbox" thing installed behind them.
Engine: 5.7 350 TPI
oh..is it a black material? most came with a sound deadening insulation cover on the back.
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
My 89 had a pair of those in it. I tossed them because they were in such bad shape. Now I have another set from a car someone was parting. I'm going to try and glass them and make an enclosures for at least 8" woofers.
They look like this, not in the best shape, but better than I had.
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Or do you mean the ones that came with the factory amp, they hold 2 speakers per side, I 'THINK' the sizes are: 4" round, and 4x6.
No, nothing fancy, just an enclosure behind the normal 6X9's. I was just wondering why some cars had them and others didn't. There doesn't seen to be a pattern.
Car: 1985 Berlinetta
Engine: 5.0 LG4
Axle/Gears: 3.08 Peg Leg
Found these on eBay last June, didn't have the cash to bid (can't remember how much they went for).
The top part holds a 4x6 and the lower hole is for a 5" sub. If anyone has seen a source for these, let me know!
Car: 89 Iroc Convertible
Check out this link
https://www.thirdgen.org/forums/inte...ound-rear.html
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
I have this setup in my 87 Trans Am. It works pretty good actually. While certainly not the equal of giant sub-woofer enclosures, they sound good and take up no extra room.
ambainb
04-25-2016 10:21 PM
db057
08-11-2015 11:11 PM
