how to put back spare tire setup?
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
hey guys.
my car is always in project mode but im finally getting around to putting the jack stand and a new aluminum donut spare and i have these hardware bolts and screws made for our cars that i bought on ebay as a set.
problem is im having trouble figuring out how it all comes together to hold everything in the place.
i can get the jack stand in place but when it comes to holding the spare tire in its kinda tough and its tough enough yanking the tire in and out with the jack in the way.
any pictures or suggestions would help guys
Axle/Gears: no idea
Re: how to put back spare tire setup?
come on guys no body?
i got this long bolt with a hook on one end.
a short bolt with a loop or ring(circle) on one end
a silver thing that twists onto one of the bolts
a circlular dish that goes in the center to hold the tire.
so in what combo does it all come together.
a photo would be great
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Not sure about the short bolt with the ring, but ...
Tire into well, then hooked end goes through center of tire, there should be a ring attached to the car body (maybe the short bolt with the ring you have), the hook 'hooks' into the ring, then the circle disc goes on the threaded end of the long bolt with hook, then the 'silver thing' screws onto the threads - tighten it down so the spare doesn't rattle.
I'll have to look to see where/how the jack is placed. I'll get ya a pic.
Car: 1992 RS
Engine: Carbed 350
Ooops! Brother in law borrowed cam - sorry.
I want to say that there is a stud sticking out maybe in front of where the tire goes, and there is a hole in the jack - jack goes over stud, and another spinner holds it on that threaded stud - I remember the jack spinner being plastic with a metal insert that threads onto the stud. I'll have to look tomorrow for you, it's getting dark here lol.
Axle/Gears: no idea
thanks,
thats how i had it before but now im trying to put the jackstand in and that circle thing is the confusing part. i cant get the hook part through to hook onto the loop cuz theres very litttle wiggle room or none. then the hook bolt is sticking out too much that i cant get tire in the wheel well. i try puttting in the jack stand then the looop bolt then the tire but the i have no room to get the hook in and finish the installation
Car: 1992 RS
Engine: Carbed 350
The spare goes in so that the backside (deep side) of the spare is against the fender, then the spare won't hit the ringed bolt that the hook goes through.
Axle/Gears: no idea
i get that and i have been able to do this so far. but now im putting back the stock jackstand and its just reallly making it difficult.
i'll figure it out i guess thanks
Car: 1992 RS
Engine: Carbed 350
Oh - wait - you mentioned aluminum spare - is it the one with a spoke look to it as opposed to a black painted rim with circular holes? Is it flat and requires the can of air to fill it if it's used? If so, that may be a whole new ball game then - I've never seen the aluminum spare installed.
Axle/Gears: no idea
yea my car didnt have a spare and i bought a aluminum one one ebay
On Probation
Heres a pic from a ragtop so a hardtop may be similar:
More pics here (scroll down):
https://www.thirdgen.org/forums/conv...pare-tire.html
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
The Jack and tool are mounted to the car with a short rod with a black cap, and the spare tire has the rod with a loop on it to tighten it down.
Car: 88 GTA
Engine: 5.7L 350
Anyone have...or know where I can get the bolts to hold everything in place? Need to the 2 hook end bolts and the one that holds the jack in place. Posed up on interior parts wanted....
Were you able to get your's in. I can take a pic of the diagram that shows how everything is arranged.
Axle/Gears: no idea
yea i got it, just gota put it back in the right order/ right side of the tire facing in
thanks
thanks
It appears there are two different type stowage depending on tire types and jacks. IIRC, the "long" type is a ratchet type, the shorter jack is a screw/scissor type.
Attached is a diagram of the stowage with a ratchet jack. The hold down arrangement is quite similar between the two.
FWIW, here's my spare install. I think I've taken it out of the car twice. There's also a curved plastic "shoe" that the spare sits on when it's stowed.
i have this space saver spare but where do i get the plastic spacer for it
and how does it lock it into to place. what is the proper hardware?
Car: 89 Iroc Convertible
The plastic spare tire rest came in cars that were equipped with a space save spare tire.I see them occasionally in junkyard cars
1992rs/ss
05-19-2020 07:02 PM
Fast355
12-02-2016 06:33 PM
1992rs/ss
16
01-28-2016 09:58 PM
