A pilllar and roof molding removal
Car: 87 Trans am
Transmission: built 700R4
Axle/Gears: BW 9 bolt posi w/ disc
Re: A pilllar and roof molding removal
youre going to get a lot of people telling you to search.. its been covered a million times.
Just go to your local dealer and order some new clips before you take them off. You WILL break all of them when taking the pillar off... your car is 22yrs old and they are plastic.
GM part number for the clips is 20462090
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
https://www.thirdgen.org/forums/body...rvation-3.html
JamesC
Thanks guys for the replies. I can see how the white clips will break but I actually broke the black part on the pillar itself.
This is my 1st restore of a 3rd gen Camaro. Usually deal with the older ones. So far, so good.
Car: 86 Iroc
Axle/Gears: GU5 323
I'm having the same issue wiyh my pillar's, where can ai get the plastic push screws? Thanks
Car: 86 Iroc
Axle/Gears: GU5 323
I've only seen the door panel style clips on some T-top cars, and then I suspect they may not have been original... The trim will usually break before the above style clip pulls out.
The ones you want are GM part# 20462090. They come 10 to a package, and it just so happens you need 10 for a hardtop. Last time I bought a package they were about $2 a pop.
Car: 1985 Camaro
Engine: 2.8l
Axle/Gears: Stock
On my 85 all I had to do to remove the A pillar was slide the entire A pillar cover toward the back of the car. The cover came off without breaking a clip. I put it back on the same way, just slid it forward.
Car: 1985 Camaro
Engine: 2.8l
Axle/Gears: Stock
The B pillar, or the cover in front of the sail panel.. That was a bi*** to get out.. Left that black plactic fastener disconnected when I reassembled it
IROCZDAVE (88-L98)
Exterior Parts for Sale
09-06-2015 06:23 AM
