Cluster for LS1 dash swap
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
1 Post
Car: 91 Z28
Engine: 6.0 LSX Single turbo
Transmission: 4l80E
Axle/Gears: Moser 9" 3.55
Which cluster is best to use for an ls1 dash swap. I have a 98 set up ready to go but im curious about the gas gauge, I know the 97 used the 90 ohm sender which is the same as ours and the 98-02 got the signal from the bcm. For people who have used a 98-up cluster, is the gas gauge still accurate? thanks
Car: 1987 GTA
Transmission: 4L60e
Re: Cluster for LS1 dash swap
The LS1 gas tanks use a different ohm sender (check the lsx swap forum here) than the thirdgen 0-90ohm. So - you'd either have to use a different sender in your thirdgen tank or use the 4thgen tank.
My recommendation? Keep the thirdgen dash and make it work with the ls1
![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
Didn't the LS gauges use a serial data line for the communications?
ambainb
04-25-2016 09:21 PM
NBrehm
08-25-2015 11:49 PM
