I can't get the rear speaker hanger screw to work!
Car: 1985 IROC-Z28
Engine: 305 HO (L69)
Transmission: Rebuilt T5 (updated T5 parts)
I was taking it off to clean under everything (not under the speaker though) and now the screw doesn't work right. can anyone help me?
Car: '85 Firebird
Engine: 2.8 V6
Transmission: stock BW 5 spd.
Axle/Gears: stock 3.42
Re: I can't get the rear speaker hanger screw to work!
these are a pain to put back in, you have to screw it back in - in a certian spot at a certain angle to hit the hole for it, either that or the thread/hole is stripped.
Car: 1987 Trans Am
Engine: LQ9/L92
I agree. These are always a pain to get back in. Just need to take some time and get the screw to go straight back. They (eventually) screw back in. I always found it funny how long they made those screws, maybe just to make our lives more difficult?
Car: 92 Z28
Engine: LS3
Transmission: TR6060
Axle/Gears: Strange S60 3.73
As mentioned above, the screw has to be at a certain angle to go in. The hanger screw hole is on a slight bow with the body so it is tricky. The screw holes are raised a bit at the sheet metal. I found this same issue with the two outer screws holding lower foot molding to rocker panel. Screws only seem to want to catch metal at a certain angle. Good luck.
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Put the screw in through the hook and sail panel. Partially install everything and pull back the top of the panel just enough to see the hole and the end of the screw. You won't be able to see it go in but aim the screw towards the hole.
Works most of the time.
Engine: 5.0 TPI
Transmission: TH700R4
Axle/Gears: 3.43 posi
I'm glad I'm not the only one who has problems with these sail panels. They are a pain to get the screw on the right angle.
Car: 1988 Pontiac Firebird
Engine: 2.8L V-6
Axle/Gears: stock
sometimes if the screw does not go back in.. you might have to try tightening up your inrerior panels around the back seats. i had the same problem.. and once i tightened everything back up, it realigned the screw with the hole and allowed me to screw it right in..
hectre13
12-11-2023 08:14 AM
1992 Trans Am
05-10-2023 07:19 PM
db057
08-11-2015 10:11 PM
