Seat Cushion/Foam....where to buy?
Car: 1990 Camaro IROC-Z28
Engine: Stock L98
Transmission: 700R-4
Where can I get the foam that goes underneath the seat covers?
Can I get it with the seat covers?
My driver's side seat has a tear in it and the foam has been severely damaged. Where can I find the foam? If it comes with the seat cover, its even better
Thanks for the help
Thanks for the help
Car: 1991 Trans Am
Engine: 5L TPI
Re: Seat Cushion/Foam....where to buy?
I don't know of anyplace selling it new (maybe GM? but probably a discontinued part). But lots of yards can sell you the foam used. Don't cringe - once you take the seat apart and take off the upholstery, it's just a chunk of foam and it can be scrubbed with Simple Green etc and it will be just fine after drying out for a day or two in the sun.
Check with places like Hawks Third Gen (hit their ad link from this site). I've bought a lot of stuff from them and they are great!
I looked for the foam for a friends car, and was told it was not reproduced at this time but was in the works. Now I don't know that to be fact or just B.S.
But if you have a place around your town that sell upholstery supplies you can rebuild/repad your foam fairly cheap.
All you need is some 1/4" thick foam, a can of spray glue and a knife, that should be less than a $50.00. And if it is real bad use 1/2" foam, and if it cut up bad on the bottom of the foam you can glue a piece of vinyl or burlap on there to keep it from getting tore up anymore.
