insulating door and floors
1 Post
Car: 1985 Pontiac Trans Am
Hey all, I have searched and come up with many threads about using dynamat and similar products.I decided to use the cheap stuff that guys mention from lowes or home depot.what is it called?look like?and where can I find it.I looked at home depot and not sure what i am looking for.Also is this what I should use on the doors in place of the plastic behind the door panels?My plastic was junk when I took it off.
Car: 1987 Iroc-Z28
Axle/Gears: G92 3.23, G80, J65 disc
Re: insulating door and floors
it looks just like dynamat but just without the name on it. so therefore is looks like black tar with aluminum foil on it, i think it comes in roles, not for sure though. i dont know if i would put it on the actual door plastic was, but maybe on the back on the door panel or none at all.
Peel n Seal. Go to the roofing section of Lowes and ask for it by name. They will know what you mean. Also, I just did my car with it yesterday. Simple and quick process. Here are some pics of it
https://www.thirdgen.org/forums/body...ml#post4128782
Car: 86 Iroc
Engine: Soon to be LS 6.0
Transmission: Soon to be mn12
Axle/Gears: Strange 9in 4.10
Well word to the wise, for it to do any good your going to want to put it on the metal actually causing the noise/vibration. Its made to kill the vibration on metal that cause noise.
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Peel n Seal in the roofing section at Lowes. Comes in 6" X 25' rolls for about $15 per roll IIRC. I did the passenger area and doors on my 89 with the stuff. I still need to get the cargo area and sail panels when I get a little more ambitious
1 Post
Thats great I figure it will help take some of the noise out of the car and the price is right.Screw the dynamat!
1Aauto
Sponsored Vendors
01-15-2016 06:26 AM
Ragtop Man
09-12-2015 12:23 AM
