Need some help with Firebird A-pillar trim
Old 04-14-2009 | 08:18 PM
Mr Froman's Avatar
Car: 1990 Firebird Formula
Engine: LB9 - 5.0 TPI
Axle/Gears: 2.73, LSD
I noticed the other day that the pillar trim on both sides is pretty loose and was wondering if anyone knew how I could get it back to normal since its going to drive me nuts until I stop it from moving all over the place.
Old 04-15-2009 | 06:11 PM
Mr Froman's Avatar
Re: Need some help with Firebird A-pillar trim
Bump. Don't wanna have to start ripping stuff apart without knowing what I'm doing first...
Old 04-15-2009 | 08:09 PM
Guest
Guest
Posts: n/a
there are christmas tree clips that slide on the trim piece. yours are either loose broken or both. you can buy replacements either from autozone or classic industries. i replaced mine when i replace my headliner, its worth it because rattles make me crazy.
Old 04-18-2009 | 11:43 PM
BahN's Avatar
Car: 1987 Trans AM
Engine: Twin Turbo 6.0 LS2
just replaced my headliner and the trim tree clips as well. Just a side note, the ones i got from autozone for gms were to big for the trims retainer piece, i just chopped a tiny bit off one side of each and they fit like a charm.
I used the white GM Panel Clips from autozone.
Best of luck.
(DONT USE THE HEADLINER REPLACEMENT CLIPS THEY DO NOT FIT)
1992 Trans Am
05-10-2023 08:19 PM
colton_carlson
03-08-2019 01:21 PM
IROCZDAVE (88-L98)
10-06-2016 10:08 AM
deracer
04-11-2016 01:04 AM
corlando52
Interior Parts Wanted
08-24-2015 12:32 PM
