looking for gauges that will fit
Is there an aftermarket speedometer that will fir on the stock cable?
I really dont understand how the whole speedometer thing works, when I took the stock cluster out, I unpluged a thick cable from the back of it. The cable it self just slid on, and had a retainer clip, inside the cable was a little blue, square shaped pin/needle. Also on the back of the speedomter gauge, was 3 wires, leading to a little yellow plug, that plugged into something else.
Not even sure what the 3 wire plug ran to, to be honest
But what is the easiest solution?
Ive seen gauges at autopart stores that says, for gm, or for ford, so would the GM one just connect to the stock cable or what can i do?
or what kind of gauges wil
Any help would be appreciated
I have an 89, IROC, with a 350
Re: looking for gauges that will fit
Second, the cable itself ("little blue, square shaped pin/needle) fits inside the black housing and runs from the rear of the speedo head to the trans.
Third, the yellow plug is the VSS (vehicle speedo sensor).
JamesC
ambainb
04-25-2016 09:21 PM
355tpipickup
Alternative Port EFI Intakes
08-26-2015 04:08 PM
R3500
08-17-2015 12:16 PM
