Getting mildew smell out of car?
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
Hey guys, I'm fixing up my 91 TA, but the smell of the interior is killing me when I work inside it, mind you, it's alot weaker than it was when I had originally started, it's still pretty gnarly. It's a t-top car, and when I got it the trunk was wet, would steam cleaning it help? Or should I get an industrial strength smell spray?
Car: 1992 firebird, 2008 focus
Engine: 3.1 6 cylinder
Transmission: automatic
Axle/Gears: stock
Re: Getting mildew smell out of car?
Your best bet is probably going to be to take the carpet out, and clean under it, and replace the carpet.
Steam may do it though. I don't think an air freshener will do anything but cover it.
1 Post
Car: '91 Camaro Z28
Engine: 383 Vortec HSR
Transmission: Pro-Built 700-R4;Vig 4000 stall
Axle/Gears: Moser M9 9" / 3.89
I had a buddy whose car got rained on pretty badly with the t-tops out. We ended up shampooing the carpet to get rid of the odor. Dry it out with a hair dryer first to get as much of the moisture taken care of, then wash it with carpet cleaner. And then work on getting that leak fixed! Last but not least, if it still smells kind of funny after that, you could use febreeze on it, but I'm guessing that would just cover up the odor temporarily. If all of the above doesn't work, just replace the rear carpet itself. You can get it for pretty cheap.
maroe624
04-16-2017 08:29 AM
