4th gen dash swap
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
4th gen dash swap
currently workin on dash swap . cluster is workin but i dont have the hot and igntion hooked up so would this cause my turn signals not to work yet?
also i have my headlight and parkin lights workin with the 4th gen switch
does anyone have the schematics for the small bezel lighting "white letters" to light up . ? i have my cluster lighten up right now
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
Re: 4th gen dash swap
how is it working if it doesnt have power?
you signals should work on the car, but its gonna need power to make the arrows blink.
Car: '91 Camaro Z28
Engine: 383 Vortec HSR
Transmission: Pro-Built 700-R4;Vig 4000 stall
Axle/Gears: Moser M9 9" / 3.89
Wow, talk about making a hot car even more badass! Can't wait to see pics of that thing when you're done!
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
well i got the thing on a while back havent worked on it.. my interior lights. go crazy .. idk if its maybe due to low battery but my hids stay on.. i only have one ground strap for the interior.. usually its two right?
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
im not sure if its a wire issue. my 3rd gen headlight switch was messed up and caused all might interior lighting to do crazy things.
new headlight switched fixed the issue. have you wired up the 4th gen headlight switch yet?
hopefully its something simple.
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
yeah actually i have.. hopefully i didnt cross anythign up .. do u have any schematics?
i guess il figure it out.. sooner or later.
also i want to have my interior lights .. dome.. etc on with the dimmer on the up position . is it possible?
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
i figured i might have just messed up on the headlight switch i might work on this on friday . i was able to get the interior lightin form the cluster im guessin the other appliances has a missing ground. .. so so far ill get the small light in the fog light switch hooked up as awell as the headlight switch lighting.
ill figure out the turn signals later.
hooked up my gauges and fan switches where the hvac controls suppose to go .. this might be temporary until i get the ac unit workin again.
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
my lights dim dome and cluster.
i dont have my notes with me from my swap, but i found this in a thread.
pretty useful.
good luck.
3rd GEN -> 4th GEN ; Purpose
-Headlight Harness-
ORANGE -> ORANGE ; Taillights Fuse
RED -> RED ; Always Hot
YELLOW -> YELLOW ; Headlight Dimmer
BLACK -> BLACK ; Ground
BROWN -> BROWN ; Marker Lights
GRAY -> GRAY ; Instrument Lights
-Dimmer Harness-
BLACK/RED -> DARK GREEN ; Dimmer Output
WHITE -> (2) WHITES ; Domelight (The 4th gen switch has 2 outputs for this, so I just spliced them both into the 1 from the 3rd gen harness)
BROWN -> BROWN ; Marker Lights (Dimmer Input)
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
wow that looks amazing.
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
thats just there for temporary use. thanks though . i was think in of the other one. same ones on the vette and camaros right?
when its wired up properly, everything should work.
pretty useful.
good luck.
-Headlight Harness-
-Dimmer Harness-
pretty useful.
good luck.
-Headlight Harness-
-Dimmer Harness-
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
well im actually going to look for a in dash within time. i dont have any speakers at the time so its just there for a visual lol
here are two more of today
some better shots
im still missing the camaro emblem. need to find a ebony dash pad and modify it to fit. as well as the missing top from the 4th gen center console. door panels. new shift ****. new seats. and pedals. audio can wait for later
some better shots
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
What are you going to do about your gas gauge? That being a 97+ cluster there is going to be problems. I do however have a solution to the gas gauge I think there is one other issue with that cluster though.
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
mind to share.? im barely getting there.. i believe the signal comes from the ecm.
Car: 91 Z28
Engine: 383 TPI
Transmission: 700R4 B&M Hammer Shifter
Axle/Gears: Stock Posi
some better shots
some better shots
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
looks good..i did the firebird dash in my car from a 96 looks killer.........eventualy ill put a 98-02 firebird dash.
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
small update its been going slow and taking me forever!!
temporary window switches mounted in my ash tray
few more
few more
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
im still debating what door panels to use. ive been lookin for a nice pair not sure about th5 4th gen panels though
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
youll spend 5 times the labor over the dash swap. the dash swap seemed like plug and play to me... these panels......
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
some final lil touch ups today gm emblem and some leds
im still looking for a dash pad. are all camaro and trans am dash pad interchangeable?
i also want to purchase a dual gauge pod for the pillar if anyone has one i would be interested.
i will need to fill in the gaps in the far corners i dont feel like molding in the 4th gen ones into my 3rd gen .
like this
but
so far so good
like this
but
so far so good
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
those are custom made fiberglass caps off of fatals car.
you dont have to mold anything.
if you get creative, you can shave the 4th gen ones down and they will look factory. just takes time.
i wouldnt buy a dashpad online.... it will likely be the wrong color, or be cracked when you get it.
GM is pricey, but you wont have to buy it twice, and it wont crack on you a week later seeing its never been baking in the sun.
my .02
my .02
Car: 91Z, 97RS, 99Z, 02Z
Engine: TPI 383 Vortec, 3800, LS1, LS1
Transmission: T56, 700R4, T56, 4L60E
Axle/Gears: 3.73, 3.43, 3.42, ?.??
Hey TPI, the swap is lookin good. It seems that you and I took the same route, but I got a question or two for ya. How did you get the milage on a digital odometer to display with an L98? I was first using the V6 cluster that has an analog odometer and now I'm using a cluster out of a Formula still with an analog odometer but would really like to use a Z28 cluster with the digital read out.
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
i have question for you guys , i just bought some c5 seats and i cant find any brackets for these. is this ganna be tough? i dont have any welding equipment or experiences . ive searched but cant find much .
Awsome, so a digital odometer cluster from a 97 will work just the same as an analog odometer cluster? Something else I was wondering about, did you have to use the converter box from dakota digital or something of the like to make the speedo and tac register correctly?
As for fitting those seats, well I don't have that answer but they look like they would go better in my car. Just pullin ya chain dude, good luck with em. How much did you give for em?
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
process is going slow.. barely going to work with the fuel gauge. .. and i need to modify brackets to fit the stock replacement.
here are some updates.
#42
Car: 92 Camaro
Engine: El Tee Juan
Transmission: Tee five six
Axle/Gears: 10 Bolt 4:10's
I started my dash swap... How do you get the plastic a/c piping to mate with the 3rd gen firewall? I just cant seem to fit it. I tryed looking at that pic of how you installed the 4th gen piping, but what did you do? I am clueless. Holding the piping in my hand trying to figure this out... I want my air to blow out the vents...
#47
Car: 92 Camaro
Engine: El Tee Juan
Hey. I'm having a lot of wiring issues... All the wiring writeups on here dont match up to mine. Im stuck on my headlight wiring still... Need some help on that
#48
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
i had some problems with the info that was given here. but i pretty much color matched the wiring and it worked. the only thin i didnt get to fix was controling the dome light and side interior light with the dimmer switch . .
#49
Car: 92 Camaro
Engine: El Tee Juan
Ok, someone help me with the wiring on the headlight and dimmer switch. The first pic is a pic of the 4th gen headlight switch's wiring. The wire on the far right is actually brown, and the wire on the left is black.
The second pic is of the 3rd gen headlight switch wires. I need to know which colors to plug where.
#50
Car: 92 Camaro
Engine: El Tee Juan
Then, the third pic if of the 4th gen dimmer switch wiring.
And finally the 4th pic is of the 3rd gen side of the dimmer wiring.
Please help
Please help
