Power door lock button
Car: 1985 Trans Am
Transmission: THM 700-R4
Axle/Gears: Stock
I'm replacing my power door lock buttons and don't know how they connect. Do you solder the wires together or is there a connector in the door that I'm not seeing?
![thank you](https://www.thirdgen.org/forums/images/smilies/thanks.gif)
Car: All sold :-(
Engine: None
Transmission: None
Axle/Gears: None
Re: Power door lock button
the buttons have little snaps that lock around the harness plug you just have to gently pry them out (it's like 2 one top one bottom IIRC) and pull; with the clips released they are simply press fit in place.
no cutting splicing is necessary.
perhaps someone has a photo, If not I can go take one on my Iroc.
but you have to remove them from the trim plate first, those are also snaps i think
Car: 1987 Z28 with iroc-z Package no.3
Engine: 350TPI
Axle/Gears: 3.73 posi
trim plate is 2 star bit screws. go gentle on the plastic tabs. there brittle very brittle.
1992 Trans Am
05-10-2023 07:19 PM
