Seatbelt warning light 4th gen seatbelts? What did you do?
Car: 2002 Camaro
Engine: :(
I am installing the 4th gen seat belts. The third gen warning light wire hooks up to the bottom retractor. But 0on the 4th gen it is on the receiver. Also the 3rd gen is a 1 wire, then 4th is a two wire? \
Any solutions?
Any solutions?
Car: 2002 Camaro
Engine: :(
Re: Seatbelt warning light 4th gen seatbelts? What did you do?
I guess that is all right. I just would like to hook it up. I am kind of fanatical that way.
Car: All sold :-(
Engine: None
Transmission: None
Axle/Gears: None
I'm going to do the 4th gen seatbelt swap in my Iroc in a few days, so I'm going to see if it can be hooked up, I'll post If I find a solution.
Car: All sold :-(
Engine: None
Transmission: None
Axle/Gears: None
I think I may have figured it out, going to try it on my car to be sure but It looks like you have to run the black wire in the Retractor (thirdgen belt) to one of the wires of the Receiver (4thgen belt) then run the other wire to chassis ground.
With the belt out of the receiver the circuit stays grounded, while with a belt plugged in the circuit is broken stopping the light/alarm buzz.
ambainb
04-25-2016 09:21 PM
