Flat dash owners and HUD install (info and pics)
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
There is has been countless topics of installing a HUD into a thirdgen. But nobody seems to have done it. Now I have swapped over to 4thgen dash but after looking into things and gathering a mixed batch of GM parts , if I had a flat dash this would already be installed and working. I plan on installing this under my 4thgen dash top though its going to be tight I think it can be made to work. I made this topic for info so people with stock dashes can attempt this with the best fitting parts found in the scrap yard.
First goto the yard and find a 91-94 cutlass supreme and pull the HUD out of it. The reason you should find one from this car is because it has a flat dash. It also has the lowest profile HUD cover. The 88-93 grand prix hud has a sloped cover but you can interchange all parts.
Here is a pic with some cutting of a spare dash there should be plenty of room for this. Best of all it "seats" in and looks factory with the cover. The cover also removes so it can be painted black with ease.
Now you need the pigtail and HUD switch/dimmer. The cutlass switch setup is recessed into the cutlass dash and isint very nice. I chose to pull the HUD/dimmer setup from a 91-93 grand prix simply for its easy of mounting and the fact it lights up in red (keep in mind these parts are all interchangeable). Here is a pic with everything you need. Noice the extra plate? the cable attaches to allow the projector to move up and down on your windsheild. I dont plan on useing the whole mouting bracket but I do plan on cutting the part that holds the cable in place and just bonding it to the bottom on the HUD. This saves space, though you would probably just use it anyway since you stock dash owners have more space to work with then me.
and a pic of everything.
Now the diagrams , all wireing is compatible unless you have a cable speedo , then your HUD speedo will read zero.
91-93 GP HUD SWITCH Connect to:
A BLK ground
B PNK/BLK switched ignition (feeds from cluster)
C WHT display dimming HUD unit D
D BLK ground
E GRY gauge backlighting (variable interior)
F BRN/WHT switched source HUD unit A
HUD UNIT grand prix/cutlass (identical)
P/N ?
(1st row)
A BLK or BRN/WHT switched ignition from HUD switch E
B BLK ground
C GRY/BLK or BRN parking light (constant exterior)
D WHT display dimming from HUD SWITCH A
E --- not known to be used, fuel if equipped (more data below)
F LT BLU left turn signal
(2nd row)
G BRN check gauge
H LT BLU english metric, grounded = metric
J DK GRN vss
K DK BLU right turn signal
L LT GRN high beam
M --- not used
A BLK ground
D BLK ground
P/N ?
(1st row)
B BLK ground
(2nd row)
G BRN check gauge
J DK GRN vss
L LT GRN high beam
M --- not used
Car: 2012 Corvette
Engine: LS3
Transmission: TR6060
Re: Flat dash owners and HUD install (info and pics)
No pics of it installed? You may have a little problem getting it to work well though. I know for a fact that the new Corvettes have a special windshield that lets the HUD reflect better, but I don't know if these older cars do though.
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
The windsheild dosent matter. I have a HUD installed in my grand prix which didn't come with one. My friend has a the same car with HUD windsheild you can't notice a difference. If there is any its very very small. All the electronics are compatible with thirdgens, the funtions rely on the cluster feed on these older HUDs. They don't reqire ODB1-2 etc like the vettes have. The main issue is fabing your dash you house it. I no longer have a stock dash But i plan on getting this into the 4thgen dash (without the HUD cover) and then make a custom cutout in my top pad.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I had a HUD in my 92 Cutlass, and the difference between the coated HUD glass and the non-HUD glass was substantial.
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
i've read this thread can someone exaplin what the hud is i never heard of it. then again im not familiar with any cutlass models. jsut curious to what your trying to do
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
subscribing. I always wondered if this was possible (as in HUD on a vehicle) and here I find the technology was available since the early 90's!
Bobby: H.U.D. Heads Up Display...information reflected on your windshield (inside)... like speed and such...
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
But as I said you can get all this stuff and it will work properly its just doing the fab work to your dash.
Car: 1987 Trans Am
as a matter of fact, I went to the junkyard on Monday to actually do this project but I did not find any Grand Prix's or Cutlass Supreme's (about 20cars total) that had the HUD. I was so disappointed. I'm extremely interested in doing this to my car... I just don't have the parts! Gnarley_Border, want to get rid of those HUD components!?
Car: 1987 Trans Am
Eventually I did find the HUD components from an OBD1 car at the junkyard, but I think it must of been defective because I couldn't get them to come on, the HUD wouldn't even light up or anything. So I still have an eye out for another "donor" HUD set because I'm still extremely interested in doing this...
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
What all shows up in the HUD? Speed obviously....Does RPM, any gauge readings?
Car: 1991 Trans Am
Engine: 5.3L
Transmission: auto
Depending on the HUD, it displays speed, high beams signal, turn signals, low fuel. Some display the radio station if you have a radio that has a data line output. Wiring is the easy part, making it look like it's supposed to be there is hard. You don't need a HUD windshield.
Car: 1991 Trans Am
Engine: 5.3L
Transmission: auto
Car: 1987 Trans Am
I forgot what car it was from, I think a Grand Prix Turbo, I can't remember the year or any other details. The problem wasn't hooking up the unit, its the fact that the unit just did not turn on at all. Not even when properly grounded and energized. I prefer the OBD1 because alot of the wires are similar color (tach wire, speedo wire, etc)... But I still have an eye out...
Car: 1987 IROC Z
Engine: 350 TPI L98 block
Is their any way you can repost those pics ? I had been holding onto this as an idea and im ready to move forward with it. How did this end up ?
Car: 1987 Camaro IROC-Z
Transmission: LS1 T56
Axle/Gears: Richmond 3.73
I have a HUD unit that I can use for this. How did it turn out?
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Well I set this thread up so flat dash owners could give it a try. I got rid of my flat dash long before I did this. But thought it would be interesting and very doable with a flat dash. I still have the parts kicking around if anyone may be interested.
Cutlass and grand prix HUD's are identical size with one difference. The grand prix uses a top cap that has a slight flow in it to accomidate the grand prix dash. The cutlass cap is flat. They both interchange as they are the same units. In fact everything right down to the switches and cables interchange.
The bonneville HUD is recessed into the dash of the car and has a full removable top that clips into the dash. The electronics will work fine though.
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
I don't know if this violates some cross-forum rules, but The W-Body Page has some HUD info that might be useful.
http://www.w-body.com/forum/index.php?board=15.0
http://www.w-body.com/forum/index.php?topic=53784.0
http://www.w-body.com/forum/index.php?topic=48675.0
Car: 91 Camaro RS
Engine: Freshly rebuilt 350 with goodies.
Transmission: 700R4 w/ 2000 Stall
Here's what I did for my senior design project, I'm looking into adapting it for use on the Camaro. Probably not as a HUD due to the optical issues. Normal windshields usually have a nasty ghosting effect.
Overview:
http://www.youtube.com/watch?v=gYJyU...eature=related
Final design on the car in action:
http://www.youtube.com/watch?v=XkVxzM0YXT8
Be looking for a development thread soon, either in interior, electronics or the ECM forum.
Overview:
Car: 1991 Trans Am
Engine: 5.3L
Transmission: auto
I don't think OBD1 to OBD2 should be a problem. The HUD needs a 4000 ppm input signal, which IIRC is what the vss outputs on our cars. The 97+ Grand Prix HUD does use a data stream for displaying the radio station, if you are using a 94-02? radio it should have that output also, but it is not required to use the HUD. Fiero guys like the 92-99 Bonneville HUD which is about the same shape.
Have you measured the flat dash HUD on your dash? Our windshield angle does not give much room. Another problem is the defroster vent and the driver side speaker.
Car: 1982 Trans Am
Engine: LG4
any huds up to '03 should work with the f-body, provided your car has the vss.
The_Phoenix
02-04-2016 08:10 AM
