Headlight Knob
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
Headlight ****
I can't seem to get the headlight switch **** off. I see that there is a little spot for a tool to fit in but no matter what I do it won't budge. Any help is appreciated.
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Re: Headlight ****
Funny, I can't get my headlight **** to stay on. So I stuck it in the center console and live with pulling on the metal rod.
Although mine never really stayed put, I think it's supposed to just pull right off. It's held on by a metal friction piece.
Re: Headlight ****
I went to the junk yard to practice on one before I tried it on my car and inevitably broke that one. The rod came out of the switch. Even with the rod and **** in my hand I could not get it off. There is a friction clip(???) on the inside but I couldn't get it to move in any direction.
Re: Headlight ****
I've got the same problem with mine!
Car: 91 LT1 RS 89 IROC-Z 350 TPI
Engine: LT1 // 350 TPI
Transmission: WC T5 // 700R4
Axle/Gears: BW 9 Bolt 3.27 //BW 9 Bolt 2.77
Re: Headlight ****
Basically if you pull the 2 underdash panals off, look under directly below the light switch. there will be a little spring loaded button. Make sure you pull your headlight switch all the way out, THEN push the button while pulling on the light rod. comes right out.
Night rider327
02-25-2016 09:50 AM
