What do you use for cleaning the plastic interior?
Car: 1992 Z28 L98 G92
Engine: 5.7 350 B2L
Transmission: 700 R4
Re: Cleaning the Interior!
A very good product I use is called,"Vinylex by LEXOL". This product specifically cleans vinyl, rubber and plastic. It cleans, shines, and protects all at once. If you have leather, they have one product to clean (LEXOL ph), and one to condition. These are the only three that I need to keep my car interiors looking good. I have used many products and IMO these work great. They cost anywhere from $9.00 - $13.00 each, and can be purchased at a local parts store to Ebay. Sometimes you can save $$ by getting thru Ebay.
Car: 2012 Corvette
Engine: LS3
Transmission: TR6060
I use Meguiar's All Purpose Cleaner. It's also safe for leather (but I wouldn't put it on my leather without conditioning it with Pinnacle leather conditioner afterwords).
Car: 1991 Chevy Camaro...
Engine: 406 With Many Mods..
Transmission: Turbo 350...Hurst Quarter Stick...
Axle/Gears: 373 Gear..Posi Rear End...
Armor All is to greasy YUK!!
Car: 1988 Trans Am, 2005 Sierra 2500
Engine: Vortec 357
Transmission: Built TH700R4 with 26-2800 Stall
Axle/Gears: GM 10 bolt 3.73 Posi
dont ever use armor all! its been proven it dries out your plastic panels/ dashboard and causes them to crack. happened to my grand am.
Car: 2012 Corvette
Engine: LS3
For protection, you can't go better than 303 Aerospace Protectant. You can actually get it locally at Ace Hardware too. For a good shine on exterior stuff and under the hood, Meguiar's Hyper Dressing is great for that.
Engine: Vortec 357
after a few times of using it, you will notice a difference in the color of the plastic, it will look foggy and discolored in areas. then its only time until it will dry out and start to stress crack.
Car: Blue 1992 Camaro RS
Engine: 305 TBI
Transmission: T5 WC
other wise, if you don't care about how shiny it is, you can just use WINDEX to clean all of the interior. thats what i do to my car, and it works really well. it doesn't dry out anything, but then again, it doesn't add shine, just gets all of the dirt and grease off.
Engine: 5.7 350 B2L
Re: What do you use for cleaning the plastic interior?
Thanks for letting us know how things worked out for you.
Car: 1990 Firebird Formula
Engine: 305 TBI (L03)
Transmission: THM-700R4
Axle/Gears: GM 10 Bolt
when i got my firebird back i never thought i would get all the dirty and yellow off till my frined told me to use Tough Stuff and i have to say that stuff is amazeing not for shining or anything just cleanin u can get it at any parts store...
1 Post
Car: 1985 Camaro Z28
Engine: 355 SD TPI
Transmission: 5spd w/Hurst Short Throw
Axle/Gears: 4th Gen 3.42 LS1 Brakes
Car: 89 RS Camaro
Engine: 355ci.
Axle/Gears: 373:1
There are 2 ways to this, first I would just use a bottle of Windex because it is not too strong or causeyour plastics any discolor and a soft brissle brush and rag, 2nd was since I am currently changing over from my grey to Black I took all my Black peices and washed them with ordinary dish soap and soft brush and layed them out to dry, then I used a light coat of tire gel on an aplicator andmade them look like new again, come to think of it I could of used some semi-gloss black spray can and re-colored them to give that light gloss that does not need to be reaplied with armorall, maybe next time I guess.
Car: 13 Ford Focus SE / 90 Camaro RS
Engine: 122 I4 / 305 V8
Transmission: DCT / 700R4
Axle/Gears: 3.895 / 2.73
The reason why you shouldn't use an "armor-all" and similar greasy products is that they are OIL based. Any WATER based cleaner/conditioner will do very well for cleaning plastic, vinyl, and leather.
I was a detail manager and that was part of the job knowing all that stuff. Blue Coral stuff is ok, but Meguiars is much better.
Location: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
I tried the new Turtle Wax "Ice" for interiors this weekend and I liked it. Seems to give a clean showroom look without the shiny look. I don't use anything on my dash pad and it is perfect with no cracks. I just wipe it down with clean water. Armour all will eventually crack these pads.
1 Post
Car: 1986 Iroc-Z
Engine: Orig. TPI + 305ci small block.
Transmission: Orig. factory 700R4
Axle/Gears: 3.23 G80
Wow, I'm really glad I decided to look up what to clean the interior with. I was about to pop open a new thing of Armor-all Proctector stuff and wipe down my uncracked-original dash. Thank you for saving my Iroc an embarrassing crack!
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
I use Meguiar's NXT Generation Tech Protect (http://www.meguiars.com/?vinyl-rubbe...n-Tech-Protect).
They have some decent interior stuff (http://www.meguiars.com/estore/produ...ectionID=12101).
I've been very happy with it. I actually found that I only need to use it a couple times a summer. In between, all I need is a damp cloth to make my interior look like I just applied it. Good stuff.
Car: 1986 Pontiac Firebird S/E
Engine: 305 carb'd V8
Transmission: 4-speed auto
Axle/Gears: Stock
Windex contains ammonia which will dry out all of your plastic. Ever seen purple tint? Just because you cant see thru your interior plastic doesnt mean it isnt doing the same negative effects it has on window tint. Plastic is a very sensitive substrate and you should only use appropriate cleaners on it depending on the type of plastic.
1992 Trans Am
05-10-2023 07:19 PM
diana227vegas
07-08-2016 12:27 AM
