Fog Light Switch
Car: 1991 RS Hardtop
Axle/Gears: 3:23
Fog Light Switch
While I'm doing my switch install for my power windows / hatch, i'm also going to be putting in my foglight switch. has anyone wired a stock switch to aftermarket foglights? Is there a diagram somewhere, I assume I can just cut the 'stock plug' and make it work by putting power and ground to it, but I just want to make sure. Whos done this?! thanks!
Car: 1992 Camaro ZO3
Engine: 350 HSR
Axle/Gears: 9 bolt/3.70's
Re: Fog Light Switch
The following is a diagram from an 86. It might be helpful:
http://92b4crs.tripod.com/86wiring/dia-pics/100-5.jpg
JamesC
JamesC
Location: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
I think what he wants to do is wire the aftermarket lights (which has three prongs) to a OEM fog switch (that has 5 prongs). I would like the same info because my aftermarket fogs work fine but I would love to wire the factory switch.
Axle/Gears: 3:23
exactly what i'm trying to do. I'm not sure about how many wires are on the switch and the fog lights. I haven't gotten chance to really look over everything yet.
Does anyone know if the plug that goes into the back of the switch is located in all cars even if they didn't come with fog lights? Where would I find it if it is? I assume if I can get that plug, I can cut the wires, and just hard wire it into a ground and fuse box, but I just want to be sure.
Thanks for all the replies!
Engine: 350 HSR
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
My 1992 I used a stock switch and aftermarket lights. Ran the power to the switch from the fuse block, which illuminated the switch, and sends power to a relay under the hood. The relay under hood supplies power to the fog lamps from the fusible link block by the battery - so the big juice is pulled from under the hood, and not in the cabin. Thus, when I turn switch on, the switch illuminates, and power is sent on a small wire through firewall and under hood to a relay, which is switched on supplying power from the fusible link block (big wires) to the foglamps.
Axle/Gears: 3:23
I found the plug buried up in my dash all taped up like you guys said it would be. It has a black wire, purple wire, light blue wire, and i want to say yellow (i think)
now heres my question... who knows what each of these wires does. I want to cut them off the harness and just hardwire them. I know how to wire them, i just need to know what wire is what. thanks!
Car: 89 Iroc Convertible
I know the 91-92 camaros have the plug for the fog light switch already to go.Its usually taped up behind the headlight switch.The 85-87 camaros have a seperate harness and do not have the plug unless the car came with foglights.Not sure about the 88-90 camaros
Axle/Gears: 3:23
Does anyone know the wiring for the 91-92? The link above has the wrong colors, and I dont want to mess anything up. Thanks guys!
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
http://www.austinthirdgen.org/mkport...ody_wiring.gif
The wiring for the fog light switch is around the bottom right of the schematic.
Axle/Gears: 3.08
Attn Mods . . . Please delete double post
Pilotrick50
09-02-2015 12:48 PM
