88 IROC armrest question...
Car: 1988 Iroc convertible
Engine: 305TPI
Transmission: T-5, swapped it in.
Axle/Gears: no clue, but I'll learn
Duh...want to remove the armrest, I don't want to mess up the round bung/cover over the upper end screw. How do I remove that without tearing anything up? I tried with a thin bladed screwdriver, thinking it might pop off fairly easily, it didn't and I don't want to try to force it unless it just needs more force. I was dinging the plastic, so I quit, came to ask. Thanks! John
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: 88 IROC armrest question...
Theres one Torx Screw at the top, and look underneath it, theres 2 more Torx screws. undo them, and it will come off.
Engine: 305TPI
Figured that part, but how do you get the round cover off of the upper screw to get it? Don't want to bugger up the plastic. Thanks for the help!
1 Post
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Bro, reread the post, he is talking about the plastic insert that covers the torx screw There is no simple way to remove, I just pry from one part to minimize damage, someone else might have a better way but I haven't found one, they are in there pretty tight
Engine: 305TPI
Thanks Duke. Might not be a 100 point car when I'm done with it. But I'm having fun.
mustangman65_79
08-11-2015 03:17 PM
