GUAGES/TACH WONT LIGHT UP. WHERES THE FUSE?
Ok I'm having a hard time finding another fuse for the guages,(if there is one) because the fuses underneath the dash that are labeled instrument and guages are still intact. The issue I'm having now is with my guages, since I've installed some white glow guages. My brother was doing the install and was having a hard time figuring out how to take off the headlight ****. Well he ended up sticking a metal pick back behind the dash because he thought he saw a release pin or something. Well turns out the metal pick touched a metal piece back there and it made a pop and now none of the lights will light up on the dash or shifter except for the blinkers, high beam, SES, and air bag. So hopefully you guys know of another fuse behind the dash that will make the lights work again or know what will fix the issue. Thanks alot
Ghettobird52
07-05-2024 11:18 PM
