t-top squeak
Car: 1992 firebird
Engine: stock 305
Transmission: stock
Axle/Gears: stock
t-top squeak
talk about freaking annoying, its driving me i just bought the car and the drivers t-top squeaks all the time. seals are good, everything looks fine and if i put some pressure on it that helps a little but please help, anyone else have this problem/solution thanks
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Re: t-top squeak
Have you tried adjusting the tops? If you take the tops off, you'll see that the pins extend into a plastic receiver on the top of the window frames, front and back. If you take the trim pieces off, you'll see that those pieces are adjustable. Try pulling them down a tad.
1Aauto
Sponsored Vendors
01-15-2016 06:26 AM
Thirdgen89GTA
11-26-2015 11:04 PM
