How much Dynamat do I need?
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
Wondering how many square feet do I need to do my whole floor and some sides (no doors)
-Cale
-Cale
Car: 89' Camaro RS--
Engine: 305--
Transmission: Automatic
Axle/Gears: 2.73--
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Re: How much Dynamat do I need?
Don't forget behind the rear seats (gas tank), the trunk area and inside the rear fenders............
1 Post
Car: 1989 GTA
Engine: 350TPI w/ Speed Density
Axle/Gears: Borg warner 3.27
I'm using damplifier pro from second skin. cheaper and better than dynomat (caution: opinion!) For really cheap, there is a product some call peel & seal, however I found a different brand. Just go to the hardware store and look for a self adhesive roof insultion. At home depot is ~$75 for 100 sqft which is more than enough to do your basic interior covering (not if you get crazy though, you might need more).
1 Post
Car: 1989 GTA
Describe "floor". Floor from top of firewall to back of cargo area? or floor from end of footspace to beginning of cargo area( beginning starts where the rear seat backs end).
I'll give you my crude measurements anyway. 85sqft for the whole floorspace (top of firewall to end of cargo area), just floor space, no inner wheel wells or inside quarter panels. 15 for entire firewall, 30 for cargo space, and 40 for just passenger area, not including firewall. Again, this is for floor only.
Car: 1985 Trans Am
Transmission: 700-R4
im just doing from where the front pass feet go until the back seats im leaving the cargo carpet alone.
1 Post
Car: 1989 GTA
40-50sq ft should do ya then. I'd go with 50 to be safe. It's better to have extra than to run out. You can always find a place for extra.
An interesting point; even if you don't care about adding weight, 50sqft on average only weighs 25lbs. 25lbs isn't a big hit considering our cars weight 3200+lbs. And if it did matter a whole lot, you probably wouldn't be adding it anyway
Car: 1985 Trans Am
oh, nah thats not alot at all, need to get a serious motor before i get concerned about weight haha
Car: 91GTA 89TTA
Engine: 305 3.8 Turbo
Transmission: MK6 2004r
Axle/Gears: G80 3.42s 3.27s
For those that have covered the outer door, can it be pulled away at a later time and be reinstalled or is it a one time thing and needs to be replaced?
1 Post
Car: 1989 GTA
The adhesive can be softened with a heat gun and peeled away once applied. Again, it's always easier in words, but it can deffinitely be removed at a later date if chosen so. However, I'm not sure if you can restick it after it's been removed once. Might not hold up any more. Your best bet would be to not cover the door in areas you feel will need to be removed.
Car: 85 Trans Am
Engine: 305 Carb
Anybody here try Fatmat? I installed it in my Silverado and it made a huge difference, much quieter. I have not used dynamat so I can't really make a direct comparision, but after installing it on the floor and doors, I have not had any issues after a year. Fatmat only runs about $1/sq ft, about a quarter the cost of dynamat, but more expensive than peel and seal. Keep in mind that peel and seal is asphalt based, products made for automotive use are rubber based. There is also B-Quiet which runs about $1.40/sq ft. Will be making this decision again soon once the bird gets out of paint so I also have an interest in how much it really takes to cover the floor and sides. I would have guessed at close to 100 sq ft to do an entire interior. Would be nice if someone that has done their whole interior would be able to share how much it really took.
gixxer92
04-12-2022 12:09 AM
