Gauge pod question..fitting?
Car: 1989 Pontiac Trans Am
Engine: Small Block 400
Axle/Gears: 2.73 Limited Slip
I know that summit has a triple gauge pod setup, that hooks onto the plastic by the window on drivers side..the part # is like 12203 I believe.. I have this gauge setup though..
http://www.sunpro.com/product_detail.php?pid=16302
and it says they're 2"..is the gauge pod going to work to fit with these gauges? if not where can I find a diff one..? thanks!
Car: '86 Z28
Engine: 355
Transmission: 5 speed
Axle/Gears: standard 3.23
Re: Gauge pod question..fitting?
1/16 of an inch is hardly anything but it could mean your gauges fitting or falling out of the hole. You could always try putting a couple layers of tape around your gauges to close the gap and hold it into the holes snuggly. There are no brackets that hold the gauges into the pod, just the size of the gauge fitting into the hole which is holding them in which is usually pretty tight. I personally have not seen a gauge pod smaller than 2 1/16"...
