sound deadener?
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
sound deadener?
Any one know of a good material to install into the walls of my trans am under the carpet and plastic panels that will have a better effect on deadening the sound from escaping the car then the stock blockers from teh factory?
Car: 1984 Trans Am
Check out the auto stereo shops. They have materials to deaden sound for the big stereo guys, although I'm not sure if it is to keep sound out or in for them. They should have sheets of different materials that you just apply to the inside of your body panels. Might be what you are looking for.
Car: 84 Trans AM (sold), 87 IROC, 09 C6
Engine: Lt1 in IROC
Transmission: 5 speeds
Axle/Gears: Moser 12 bolt tru tracker 3.42
If you've ever watched "Overhaulin", they always install "dynamat" ( at least I think that'st what they call it) under ever square inch of carpet when they are putting a car back together...........i've seen it used so many times, I wil proably buy some and put it down in my 87 IROC when I change the carpet and seats. it works to insulate against noise and heat............
Car: 87 Camaro IROC
ya dynamat is the ****. i have a patch of it covering the backside of my license plate cuz it vibrates when i play music.
install dynamat then your underlay carpet and then the carpet.
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
There are different types of Dynamat for different area and applications. You can buy rolls, spray for hard to reach areas, padded rolls for under the hood. It is a very good product. I have approx. three hunderd pounds of dynamat in my car.
