What removes the adhesive from tint ?
The tint on my hatch is old and bad, its gone now, but its left a film on it that hinders my ability to see properly. It looks like I am looking through water without goggles on. I've tried some basic adhesive removers with no luck.. any suggestions?
1 Post
Car: 89camaro rs
Engine: 350tbi (needs carb!)
Axle/Gears: 32x in process
i heard of using some sort of cleaner and then you spray the cleaner on a garbage bag and then plasing tha garbage bag on the hatch(underside) and wait for it to dry(leave car in the sun).then just peel off. i havent tried it becouse i havent had the time for it becouse. im in the same boat as you.i just have a crapy tint job i want a new darker tint.or just pay a professional tinter. curious does your defogger system work
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
Acetone will remove it. I would try a small section first. Don't get it anything plastic (it could damage it). Not sure what it will do to the Rear Defroster though.
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
WD40 removes glue and other adhesives. Goo Gone also works but has a solvent base.
Car: 1981 & 1983 Camaro Z28
Engine: 81 - 350 (ZZ4 355hp) 83 - 305 LG4
Transmission: auto - 81 - 350 Turbo / 83 - MX4
Goof Off works VERY WELL TOO
Car: '88 gta
Engine: 350 tpi
yea, im doing the same thing here too. i believe with the garbage bag trick you spray full strength ammonia on the adheisive, cover both the inside and outside with a garbage bag, then let it sit out in the sun for a while. just so the ammonia doesnt evaporate, otherwise its no good.
im using full strength ammonia to remove the adhesive off mine, along with a ton of razors. you can try #0000 steel wool to pick up any little peices of adheisive ya missed, just so long as the steel wool is well lubricated with ammonia.
i've tried goo-gone myself. it works, but it seems to do it a lot slower than ammonia.
You have to watch usng straight ammonia it can etch your glass and really make a HUGE mess that will require replacement and it doesn't show up immediately it may be afew weeks to a year before you see it.....I used to be a professional window washer, I am telling you from experience.
They sell a tint kit removal at the local auto parts store comes with spray and razors. It s not the best but does work and it is a pain in the ***. Tok me a couple of hours for both doors. Now my hatch is falling apart oh joy.
1 Post
Car: 1987 Iroc-z Convertible
just use acetone. it will not hurt anything at all. all the plastics in the back and the quarters and kick panels are unaffected ( I use acetone to clean them and never had a problem) sill panels on the top of the door and the step sill plates will melt though so stay away.
Car: 1992 camaro
Axle/Gears: 3:73
Well the way I did it was spray a little window cleaner on it and take some kind of scraper to it. You might break a bunch of razor blades and it takes some time to do but it will come off.
1 Post
Car: depends on the weather
Engine: several
Transmission: all manual
Axle/Gears: lots
Tint off tin t adhesive remover works good, but I don't know where to get it. Someone gave me a bottle years ago and it is now gone. Windex and a razor blade also works great.
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
Glass cleaner and a FRESH razor blade then use very fine steel wool to go over all of the glass.
Kevin
Kevin
Car: 1987 Camaro Z28
Engine: 5.3L
Axle/Gears: 3.42LSD
How would you get spray paint off of the glass. Some idiot who had the car before me spraypainted the back glass.
1 Post
paint stripper on a rag and be real careful on the edges. or just use a razor scrapper and hold at about a 15 degree angle. should come off pretty easy with the razor.
