How to remove black plastic trim from door panels.
Car: 91 B4C, 17 C7 GS, 16 Denali DMax
Engine: LS3, LS3, LML
Axle/Gears: 3.23, 3.42, 3.23
I have a pair of window sweeps attached to the upper black plastic pieces I want to remove from a set of door panels.
I have the door panel off so the nuts/plastic studs are exposed on the backside. I can get them to spin, but they do not thread off. I also tried taking a small flat blade, sliding it under the nut to apply some upward pressure while turning and still nothing.
Does anyone know how to remove them without destroying them?
1 Post
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Just take a set of needle nose pliers and remove the inverted nuts, either by inserting the pliers inside the nut or by removing from the outside. I am not sure if anyone makes an insideout socket but my method works for me
Fronzizzle
03-18-2019 08:29 PM
