Seatbelt Recall
#501
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F
Re: Seatbelt Recall
After being disrespected by customer service, I quickly went to GM Corporate about this issue. I specifically told the woman that she would have to get her head out of technology and look in the books, cause I highly doubt she will find it online from 31 yrs ago. She held a 2 day investigation and closed it saying she couldn't find it. Those few of you who are actually getting this done... How?!
#502
Car: 1988 GTA 5-spd TPI
Engine: 5.0 TPI
Transmission: T-5 baby
Axle/Gears: 3.45
Re: Seatbelt Recall
#503
Car: 82' Z28 Crossfire
Transmission: Turbo 350
Re: Seatbelt Recall
Man that would be awesome! Was the letter year specific though? Cause I know only the buckles had problems in 82.
#504
Car: 1985 Z28 & 1997 Z28 SS SLP
Engine: Sbc 305 TPI & LT1
Transmission: 700r4 and A4
Axle/Gears: 9 bolt Posi 323 & Posi 323
Re: Seatbelt Recall
My driver seat belt stopped working this past year & I searched this site finding info on the recall. went to local Chevy dealer who was no help, called the corporate # re: recalls & went through all the hoops/extensions, even had recall #, but was denied. Any ways, went to junk yard & found replacement. I think Hawks sells a repair kit as well, but so far so good w/junk yard replacement, For a while, I used the female end from back seat, but it was a pain cuz it was shorter, Also tried slinging over to passenger side, but not good either. Best wishes
#505
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Re: Seatbelt Recall
They aren't required to fix it anymore:
Check the following link, which includes the info below.
http://www-odi.nhtsa.dot.gov/cars/pr...allprocess.cfm
re there any limitations on my right to have a recalled vehicle remedied at no charge?
"Yes. There is a limitation based on the age of the vehicle. In order to be eligible for a free remedy, the vehicle cannot be more than 10 years old on the date the defect or noncompliance is determined. Under the law, the age of the vehicle is calculated from the date of sale to the first purchaser. For example, if a defect is found in 2003 and a recall ordered, manufacturers are required to make the correction available at no charge only for vehicles purchased new in 1994 through 2003. However, consumers should realize that even though manufacturers are not obligated to remedy safety defects in older cars, a safety problem might still exist. If you receive notification of a defect on a vehicle older than 10 years, take the responsibility to have your car repaired at your own expense – and eliminate unnecessary safety risks.
"Also, if the manufacturer challenges the agency’s final decision of a safety defect, there is no obligation for the manufacturer to remedy the defect while the case is in court. If you decide to have your vehicle remedied at your own expense while the case is pending and the court upholds NHTSA’s final decision, you may be entitled to reimbursement. (Be sure to save all receipts and paperwork so that you can prove the repairs were made.) However, if the court ultimately rules the defect is not safety related, Federal law does not require that the manufacturer reimburse you for the repair work."
JamesC
JamesC
#507
Car: 88 Camaro
Engine: L98 350
Re: Seatbelt Recall
Need to keep in mind this was a safety recall, no time limitation on these. But we're dealing with the new GM now, so the bankruptcy probably cancelled all obligations of the old company.
#508
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Re: Seatbelt Recall
Lake:
I had the SAME issue!
Dealer and GM gave me the blowoff with recall number and info.
The few lucky members here that got the fix either knew somebody or had a clueless dealer (who prob. got backcharged for the repair) and found success.
I just went to the local parts yard and got a set of female reciever and sleeves out of a late 70s Olds Cutlass.
#509
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Re: Seatbelt Recall
I went down/called for the "recall" repair BEFORE the GM BK and got the blowoff
ALSO: READ the above gov't rule post..............
Here..I will post it AGAIN so u can read it:
NOTE: SAME deal with the gas tank recall too!
#510
Engine: 5.0 TPI
Axle/Gears: 3.45
Re: Seatbelt Recall
TOM........Thats INCORRECT!
Sorry, the page you requested could not be found.
It may have moved to a new location. Please click on the tabs above to help find it or go to http://www.safercar.gov
#511
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Seatbelt Recall
All their required to do,"if their required at all"is to change these, http://www.ebay.com/itm/PONTIAC-FIREBIRD-CHEVY-CAMARO-SEAT-BELT-BUTTON-REPAIR-KIT-OEM-GM-/220854461892?pt=Motors_Car_Truck_Parts_Accessories&hash=item336bf3a5c4&vxp=mtrI know in NJ,their is no expiration date on a Safety Recall.
#513
Engine: 5.0 TPI
Axle/Gears: 3.45
Re: Seatbelt Recall
All their required to do,"if their required at all"is to change these, Pontiac Firebird Chevy Camaro Seat Belt Button Repair Kit GM | eBay
also this part was only like 3-4$ ordered through dealer. I bought it and they installed it free due to recall letter.. hope I didnt give it to them
#514
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
Re: Seatbelt Recall
Page Not Found
Here's what I found when I entered my 89
http://www-odi.nhtsa.dot.gov/owners/...Results.action
Hmm the link doesn't seem to be working.
Just go to http://www.safercar.gov/ and click on the recall search button then enter your car year, make, and model to see recalls on your car. There seems to be about 6 outstanding for my car. I didn't go any further to see if they are still valid or not.
#515
Car: 88 Camaro
Engine: L98 350
Re: Seatbelt Recall
After reading this I got looked on Ebay, bought a set of buttons and springs in the kit for $11 with free shipping. Mine still work but look like crap, matter of time probably. Fairly simple to replace, sort of like unlatching and pulling out a stereo with the little release tool. Not worth the hassle of dealing with the service department, I hate those places anyway.
#516
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Re: Seatbelt Recall
I ordered a set through one company and they sent me a tool to remove the old buckle button.. Haven't done it yet tho
Also to answer a question, there was the literature here on the website at one time for the recall... Print that out and take it in.
The only thing I do not like is Dealerships, they do not give a crap about your car especially if it is at all nice, it is a car, no one touches my car unless I cannot do it, IE Tires and creating exhaust pieces are a bit my abilities.
John
John
#517
Engine: 5.0 TPI
Axle/Gears: 3.45
Re: Seatbelt Recall
John
John
#519
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: Seatbelt Recall
well, if you do go, be ready for lies ,deceit, and a general run around. I printed the info and took it with me to the dealership. and they flat out denied it ever was issued. in the end ,I just found the front seat buckles in pull a part. solved my issues.
#521
Engine: 5.0 EFI
Re: Seatbelt Recall
Don't loose a days work or something for free over these http://www.moderndaymuscle.com/inc/sdetail/196/688,this is all they change.
#522
Engine: 5.0 TPI
Axle/Gears: 3.45
Re: Seatbelt Recall
if you are referring to my post that was referencing just work being done at a dealerships (okfoz) in the previous post. I did not take off time for this one change...
#524
Car: 1989 Pontiac Firebird
Transmission: auto
Re: Seatbelt Recall
I just picked up a 1989 Firebird Formula last weekend for my son's first ride when he turns 16 next year. Of course I am going through the car to "fix" and "repair" to make it a safe and dependable ride. My first step is to get the sealt belts working correctly. I did track down an already repaired drivers side front and did a swap, as the buckle was all broken up. I also purchased one of the repair kits. Unfortunately, i figured the tool and instructions would come with it, as many others have posted, but it did not. I was looking to see if anyone could copy the instuctions and send them to me or post them. My hope is i can repair the remaing three belts without the tool.
#525
Re: Seatbelt Recall
ceccacci316
Howell, MI, not too far from me, My doghouse is just south of the Birch Run area...
If I get a chance I will make you a copy... it was pretty easy, I did 3 cars (12 belts) in less than an hour and a half... The first belt took me the longest, then once I figured it out it was pretty easy...
The hardest part is getting the spring back in if it comes out... But that again once you figure it out it ended up not being a big deal...
John
John
#527
Transmission: auto
Re: Seatbelt Recall
John,
Yes, Birch Run, is close .... and we both have the outlet malls in common
Thanks I would really appreciate it if you could get me a copy of the instructions. I just want to ensure I do it right so i dont destroy the buckles. Did you need the "tool" that some have mentioned to do the repair? Or can it be done with standard tools?
Nick
Nick
#528
Transmission: auto
Re: Seatbelt Recall
tom3, hmmm, it looked easy except for the struggle with the spring ... i read somewhere that someone said to keep the buckle plugged in would make it easier to insert the spring, i wonder if that is in the instructions.
Nick
Nick
#529
Engine: 5.0 EFI
Re: Seatbelt Recall
Not much to it seems like, Hawk's video on youtube:
82-92 Camaro/Firebird Seat Belt Push Button Kit Installation Video - YouTube
Is it really this easy?
#530
Re: Seatbelt Recall
That was about it... It was not a big deal... I did mine in the car, and the spring was the biggest hassle...
Maybe it only took me 1/2 hour to do all three cars, I know it was not long... I was doing all sorts of small stuff that day... I used the little sheet metal tool was supplied too with my kit, which I forget what I used it for, it might have been to put it back together... Some people do not use the metal clip on the edge like in the video, I did however...
John
John
#531
Engine: 5.0 EFI
Re: Seatbelt Recall
I think that clip was used so the Dealer would know if they were replaced in the recall.
#532
Re: Seatbelt Recall
I was able to remove about half of my buttons without breaking them, the other half I broke when I popped them apart...
John
#533
Car: 1986 IROC-Z
Engine: 90-95 ZZ4 Crate 350 TPI
Transmission: 700R4 4spd Automatic
Axle/Gears: 3:73
Re: Seatbelt Recall
The dot has the recall listed on there site, mine has never had it done either, you can tell bc there is a little metal clip beside the button if has been done.
Here are the recall numbers for the seatbelts
Seat Belts: 172,863 1982 - Belt anchorages weak (82V-089);
738,485 1983-85 - Shoulder belt doesn't retract (85V-169);
34 1989 Camaro - Webbing on buckle too long (88V-191); 1,500,000 1984-90 - Sunlight weakens plastic buckle components (90V-105);
40,696 1991 - Metal latch plate won't engage buckle (91V-067);
1,573 1997 - Retractor locks on slopes (96V-219).
Ill see if I can find the site I am talking about.
#534
Car: 1986 IROC-Z
Axle/Gears: 3:73
Re: Seatbelt Recall
Man, I have the same problems...really would love the part numbers...problem is, dealers don't supply replacement parts for cars that are over 10-years old...at least that what I got from young Chevrolet. here in Utah. Now the question is: since the recalls are spanned across several years, I wonder if there are businesses around that can repair the retractors, re-web. Thoughts???
Please do man...I am interested...
#535
Re: Seatbelt Recall
I did the recall on my TTA back when it first came out like 20 years ago. Last year my front driver was not working and since the beechwood plastic was all beat and torn I just got the entire NOS set off ebay for a rediculous price. For the backs only the red button looks like crap. Can somebody please post the part number for the red button kit- they should have this through the dealership still I assume.
#536
Engine: 5.0 TPI
Axle/Gears: 3.45
Re: Seatbelt Recall
I went back a few pages and tada!
http://members.shaw.ca/crussel/recalls/90c22/90c22.html
Parts Information
Parts required to complete this campaign are to be obtained from General Motors Service Parts operations (GMSPO). To ensure these parts will be obtained as soon as possible, they should be ordered from GMSPO on a "C.I.O." order with no special instruction code, but on an advise code (2).
PART NUMBER DESCRIPTION QUANTITY/VEHICLE
14097930 Push Button Kit
Each Kit Includes:
4 Push Buttons
4 Button springs
4 Protector Shields
https://www.thirdgen.org/forums/atta...ll-recall2.gif
I did that for you. you are welcome.
IROCullan (06-11-2020)
#537
Re: Seatbelt Recall
THANKYOU, Sometimes on these threads I notice people get sidetracked and I skipped ahead and missed this page- my apologies Maybe some day I can return the favor. I have owned my car for 25 years so somewhere down the line I might have some useful info for you guys -cheers
#538
Car: 89 Iroc Convertible
Re: Seatbelt Recall
I tried to get some thru my buddy who works at a Chevy dealer and found out that the pushbutton kit has been discontinued.You might still be able to order them online
#540
Engine: 5.0 TPI
Axle/Gears: 3.45
Re: Seatbelt Recall
I will say that mine look great except for the silver part that shows on the inside of the buckle...see?
I had the original recall letter from the pontiac from the previous owner and brought it in and they ordered the part and installed it all for free. I was told that safety recalls never expire because its dealing with safety of the vehicle. There is a letter like mine scanned on this thread and I know they could check the record of my VIN and tell it was never done. I would think they should get the part for you and if they cant and you show a letter I would think legal action would be in order. I do believe I still have that recall letter from pontiac. here is one from this thread from Chevy
again safety recalls should never expire unless the company goes out of business (pontiac but not chevy..same part right?)
if so contact the national Highway safety administration at the number on the letter if you are not satisfied.
#541
Re: Seatbelt Recall
Hawks Might have them http://www.hawksthirdgenparts.com/
Modern Day Muscle used to have them, http://www.moderndaymuscle.com
beyond someone that has purchased an excess on accident, not sure where else you could find them. I know when I bought mine they were $4.00 for a set of 4...
#543
Re: Seatbelt Recall
The red (probably now pink) button on your seat-belt receiver were prone to cracking and breaking. So you get a new spring, a new red button (actually 4 of them) you just have to pop out the button and the spring and pop the new one in. Getting the spring back in is the biggest pain, but it too is not too difficult once you figure it out.
Then once you get it back together there is a metal clip/guide that you slide on it too that is supposed to help keep the wear down on the plastic pieces. Some people forego the metal guide piece... (I would recommend using it) I have to say that.
#545
Re: Seatbelt Recall
Also IIRC, the 1992 buckles were a slight redesign. They still work with the 84-91 belts, but they got a new part number. I bought one for my 1989 as the plastic sleeve was broken on my and it was limp, but it seems to have worked.
I think the 84-91 did not have the UV Inhibitors in them or not enough of it to be useful, so they bleached out and they got brittle.
John
John
#546
Transmission: Pro-built 700R4
Re: Seatbelt Recall
My front passenger's seat buckle finally took a poo. After reading all the stuff above and on the NHTSB website, it is obvious that our cars do not qualify for a free repair any longer. I tried to find the kit (p/n 14097930) online as I remember seeing them all over the place years back. Well, they are not nearly as plentiful anymore. I called a few dealerships and there are only a few left that have any of those kits. I found one kit on fleabay, but it was asking $25 for the kit. They are only $4.85 at the dealerships that still have one.
I just wanted to pass this info on to anyone that might need a kit now, or might need one in the future. If you need one, get them now. The guy I talked to said there were seven left in the system. If you are on the West coast, you'll need to make some calls. He said there weren't any listed out here. They were all at dealerships on the East coast.
sc0TTi (04-01-2021)
xbazzarex
12-01-2015 06:25 PM
