Window triangle window guide rubbers?
Engine: 350 - 305 801 Heads
Axle/Gears: Stock
I dont know technical name for these but I know I need them. lol
The triangular seals for the windows have a channel or track rubber guide that guides the window at the bottom.
I am doing a complete restore but cant find these replacement rubber guides. There about 8 inches long and black rubber. I tried to remove but they crumbled in my hands.
I really want them in new or good shape. Thanks in advance
Peace
tec
Searching for the rubber guide that is laying horizontally. Its about 7 inches long. Dont want triangle or metal. Just the rubber guide weather proofing.
In the yellow is what I need. Thanks in advance!
Peace
tec
Axle/Gears: Stock
Re: Indow triangle window guide rubbers?
Thanks Bob
Axle/Gears: Stock
Wow No One? Boo Hoo!
Axle/Gears: Stock
Thanks in advance.
Axle/Gears: Stock
Re: Window triangle window guide rubbers?
Thanks guys and gals. I think I have a set on its way but I may not even need them. I took some black carpet and laid it down in the channel then riveted it in. Then folded over the excess trimmed and glued it. Created a nice pocket/slit to let the window slide in. I understand these are really one part of the window triangle and not a part that you can order. I will get back to this post if the ones coming are not needed. Thanks again tec
Axle/Gears: Stock
Thanks guys n gals. I got a set thanks to firebirddude142. Thanks
RPM WOT L 98
01-05-2021 08:00 PM
Rule69
Mid-West Region
03-31-2016 03:48 PM
UltRoadWarrior9
03-29-2016 06:48 AM
