Headrest Guts/Accessories Needed!
Engine: 350 - 305 801 Heads
Axle/Gears: Stock
Reupholstering seats and the guts that hold the headrest shaft have disintegrated. There is a rectangular plastic piece that the shaft fits into. Inside of the set itself is the guts that hold the headrest. I know it sounds stupid but dont know the name.
I need both sides so to do the proper reupholstering job.
Axle/Gears: Stock
Re: Headrest Guts/Accessories Needed!
Yes. thats the puppy! I dont even know what to call it to search for it. Any ideas? Thanks for your reply!
Axle/Gears: Stock
Thanks for that post brother. Would you have a pic of the other accessories that go with this. The trim on top with screws and anything else that makes if function. Im trying to buy but cant find due to name or whatever reason. I have someone in here really trying to help me out, by getting the pieces. Thanks indvance!
No Problem !
That piece pictured above ( call it a "track" ) is mounted to the front seat back-rest frame by a rivet. I seem to remember a clip, the retaining-clip might also be mounted by same rivet too. ( It's been a long time since I've been inside a seat ! ) It should be mounted to the frame before the seat cover is installed.
This is really the only other piece:
This head-rest trim covers the hole for the head-rest post in the fabric and is screwed to the top of the "track" with Philips-head screws.
Hope that helps !
Hope that helps !
Axle/Gears: Stock
Thanks for that! I wonder why I can't locate on the web? I guess cause I really dont know the name of it. Thanks again!
