[NY] Need Iroc steering wheel hardware
Car: 1989 Camaro Iroc-z
I'm in the middle of swapping the RS style steering wheel to the Iroc style.. and apparently I need some extra hardware to get this to actually work. For the Iroc wheel all I have is the wheel itself and the horn cap, that's it. Does anyone know what else I need to get this working? Thanks!
Re: Need Iroc steering wheel hardware
Sounds about right...do you know where I could get one of these?
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
i did that switch. it should work fine. The IROC wheel has some screws that hold it to the metal hub that attached to the column. The hub looks like a metal octopus,
the trickiest part of the swap is getting the horn to work, the way the two steering weeks operate the horn are totally different. I I had to take a female electrical connector that slid down firmly on the post that has the terminal on it.
No I do not.. when I bought it off the guy I only got the wheel and the horn button.
I could have sworn you should have on on your old wheel.... but maybe not.
yes, I made a metal frame for the inside of the cylinder that I glued the broken parts to, and then sanded it, and repainted it with spray on bedliner for texture. looked great
Car: 87' Pont GTA
Engine: 5.7L
I have some of the IROC Metal Steering Wheel Adapters (hub) in stock. They run $10.00 each plus shipping and handling. I also carry the Cap Screws which runs $.50 each. If you have any questions or other needs we can be reached at (805) 522-2539.
Thank you,
Thomas
Thank you,
Thomas
Hey thanks! That'll help out quite a bit... so I'm guessing all I need is the hub, screws for the wheel, and the horn wire.
that's a a reasonable price Thomas. While you're at it, he's going to need that horn wire. (part number 7 in the scan of the manual I posted)
You might want to shoot him a price for that too.
EDIT: see? LOL
EDIT: see? LOL
Car: 87' Pont GTA
Engine: 5.7L
That is true. You will probably also need the Horn Wire which runs $3.00. So, for the Adapter, 6 Cap Screws and Horn Wire you would be looking at $16.00 plus shipping and handling. Here is a picture of those items. If you have any questions or other needs we can be reached at (805) 522-2539.
Thank you,
Thomas
Thank you,
Thomas
Lol perfect! This worked out better than I thought it would. Yeah I'll take all of that, how do I go about paying for this?
Car: 87' Pont GTA
Engine: 5.7L
We accept Credit Card by phone or PayPal. Our PayPal Address is TomAtTrc@aol.com. If you have any questions or other needs we can be reached at (805) 522-2539.
Thank you,
Thomas
(805) 522-2539
Thank you,
Thomas
(805) 522-2539
Alright I'll have that sent out today then. So what's the total with shipping and everything?
Car: 87' Pont GTA
Engine: 5.7L
The weight is 2lbs. and if we are shipping to New York the shipping and handling will run $10.00 which would bring your total order to $26.00. If you have any questions or other needs we can be reached at (805) 522-2539.
Thank you,
Thomas R. ***
(805) 522-2539
www.houseofcamaro.com
Thank you,
Thomas R. ***
(805) 522-2539
Car: 1986 CAMARO IROC-Z
Engine: 5.7 350 TPI SWAP
Transmission: AT
Thank you,
Thomas R. ***
(805) 522-2539
Thank you,
Thomas R. ***
(805) 522-2539
Thomas I would like to know how to get the hub and bolts from you. My email address is I have a iroc steering wheel with no metal mounting hub. Let me know. Thank you.
Transmission: AT
How do i order thomas??? Do you take paypal??? Email me with info please.
Transmission: AT
nevermind i read the post above. i will send payment asap. thank you.
1 Post
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
Thomas....do you buy parts? I have 91 leather airbag camaro wheel I don't need. normal slight lifting of the leather by the horn buttons on top, but otherwise in perfect shape.
Transmission: AT
Got my steering hub from Thomas. Great help Great part fast shipping. Thank you Thomas!!!!!
Car: 87' Pont GTA
Engine: 5.7L
Glad I could help! I has been my pleasure.
Thank you again for your business and support,
Thomas
Thomas
backtothe80s
09-05-2015 12:39 AM
