Delco Radios
Car: 84 Trans Am
Delco Radios
I have several delco radios for sale. All have been refurbished with Aux Jack installed. Message me with what you need.
Several different Camaro Radios from 3rd and 4th gens. Yellow letter 90-92 radio. 84 Trans Am radio. 85-92 Firebird T/A radios
ggg (08-22-2021)
Re: Delco Radios
Just our of curiosity. What does a refurb with aux jack cost? I'm trying to get mine unlocked, and the horn pad working again. So I can't say how well mine performs, but a aux jack would be nice.
This is the radio I have:
Car: 84 Trans Am
Car: 84 Trans Am
Re: Delco Radios
Car: 1985 Camaro Z28 IROC
Engine: 5.0L TPI H.O. 215HP STOCK
Axle/Gears: GU6=3.42
Re: Delco Radios
I would like to have an OEM radio for my 1985 IROC, even though it is a radio delete RPO (wife's mandatory requirement to have one). Does anyone know if the 85 IROC came with a cassette player with an equalizer? How much $$$ if there is one available?
Re: Delco Radios
I have an '82 Z28 with the analog radio display and digital clock. The radio doesn't work well. I'm looking for an '82-87 Camaro radio (green display) that works well. If you have any that look good (show car), let me know what you have and how much. I don't need the AUX jack if it's on the face of the radio.
Car: 1992 Chevy Z28 - Black
Engine: ZZ4 350 HSR w/ 100 shot
Transmission: Automatic - Hurst dual gate
Axle/Gears: Moser 12 bolt 3.42 Eaton gears
Re: Delco Radios
If the 90-92 is available in will paypal immediately. Text me @ 917-968-9999
Re: Delco Radios
The current clock display is green and the radio itself is analog. The text on the radio face is white. I'm looking for the Chevy side of things that have the white text and green display. Thanks
Car: 84 Trans Am
Engine: LB9 305
Transmission: AT
Re: Delco Radios
My 1989 IROC-Z Convertible. could use an OE unit. The SPID is missing so I don't know what it came with. price and avail, please. 94954
Car: 89 IROC/89 Vert/87 Vert/89 GTA Vert
Engine: 5.7/5.0/5.0/5.7
Axle/Gears: 9" 2.77/9" 3:23/9" 3:42
Re: Delco Radios
Car: 89 Formula 350 CC1
Transmission: MD8
Axle/Gears: G80 GW6 J65
Re: Delco Radios
rarebmx, do you repair these radios? My 89 Formula has the OE UM6 cassette. One channel practically has no volume on the sound and the other just seems low. Then after having it on for a while it typically starts blasting static starting off intermittent and getting worse. The volume **** has no effect on the static but does maintain control of the volume of what your trying to listen to. I've had thoughts of pulling it apart and scoping around inside, schematics would be great though. It could just be a cold solder joint. If fixed adding rear panel aux jack would be great. Any suggestions or is this something you could repair?
Car: 1987 IROC Original Owner
Engine: LB9
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
Re: Delco Radios
He does fix them and can add an AUX jack for you that I would highly recommend.
He repaired the original from my 91 Z28 and added the jack that I ran through the ashtray - plugged into my phone the music is far better sounding than anything the tuner can pick up!
Car: 84 Trans Am
Re: Delco Radios
Car: 1989 RS Black Vert
Engine: 305 TBI
Axle/Gears: 2:7some thing
Re: Delco Radios
Looking for a yellow radio for my 91 Z.
Do you have one still for sale.
Text 4802461059
Thanks Craig
Text 4802461059
Thanks Craig
Car: 84 Trans Am
Engine: 4++,350 & 305 CIs
Re: Delco Radios
(Dot) So I can find this later
Car: 1984 Pontiac Trans Am
Engine: 305 V-8 H.O.
Transmission: 5 Speed Manual
Re: Delco Radios
Hello ~~ Do you have a UU6 or a UU7 radio that is stock for a 84 trans Am ???
If how much do you want for one of them, plus shipping to 95821
Thanks ~~ Don
Thanks ~~ Don
Car: 1992 Camaro RS 25th Anniversary
Engine: 305 tbi
Axle/Gears: stock
Re: Delco Radios
My '92 RS came with a cassette with yellow letters and I bought a CD radio off this site for it that is supposedly rebuilt and looks absolutely perfect but it ejects the CD as soon as you put it in. Can you fix it? Maybe add a jack to it also? OR should I just sell it.
Car: 84 Trans Am
Re: Delco Radios
I can fix it, and add AUX. PM me for details.
Car: 84 Trans Am
Car: 1989 TTA
Engine: 3.8 Turbo
Transmission: 200R4
Re: Delco Radios
I think my radio is the same as this,can you rebuild for better sound quality add an auxiliary and an rca output?
How do you switch between the auxiliary input and the radio itself?
Car: 84 Trans Am
Car: 84 Trans Am
Car: 84 Trans Am
Re: Delco Radios
Standard Camaro radio with aux $150
Late model Pontiac EQ radio with aux $175 (90-92 cars but will work with all years best to be 85 and up)
85-90 Pontiac EQ radio with Aux $225
84 Pontiac UU6 with Aux $350
90-92 Camaro Yellow letter with aux $325
All radios and have been fully serviced and rebuilt. I can add bluetooth in place of the Aux Jack if you want a wireless option.
Not the best pictures but let me know which one you are interested in and I will send you a video of it powered up playing. Yellow letter radio will be available in a few days. Waiting on parts to be delivered.
#45
Car: 1988 IROC-Z
Engine: L98 - full intake & exhaust boltons
Transmission: Bowtie 700r4, 2400 rpm stall
Axle/Gears: Borg-Warner 9bolt, 3.45 gears, posi
Re: Delco Radios
Do you have any white letter faced delco CD player radios? I'm looking to replace my factory UX1 unit in my 1988 IROC. Thanks.
#47
Car: 1989 TTA
Engine: 3.8 Turbo
Transmission: 200R4
Re: Delco Radios
Lapier0412 (05-18-2020)
#49
Re: Delco Radios
i need stereo for 89 iroc, aux jack and rca hookup. Got anything? Price?
#50
Hey Matt,
Just checking in to see if you've looked at the radio I sent you a while ago. You haven't replied to the emails I've sent recently so I'll try here.
Thanks!
Kevin
Thanks!
Kevin
