[NJ] Kenwood Audio System: Amplifier, Subwoofers & Enclosure for Camaro/Firebird
Car: Camaro RS
Engine: 415 c.i.
Transmission: Glide
Axle/Gears: 4.56
Price: $200 Firm
Contact: PM or mc73nova@yahoo.com
Description:
This is used and in great working condition. It is still in the car and you can hear it before I pull it out, if you would like.
AMPLIFIER DESCRIPTION:
Kenwood KAC-7201 two channel power amplfier
* 800 Watts max power
* 150 Watts x 2 max (4 ohms) RMS
* 460 Watts x 1 (4 ohms) RMS
* Frequency response 5Hz to 50kHz
* Built in variable low pass filter (50 - 200Hz)
* Built in variable high pass filter (50 - 200Hz)
* Bridgeable
* Speaker level input
* Gold plated input & output terminals
* Integral cooling fan
* Complete with full fitting and operating guide
SUBWOOFER DESCRIPTION:
KENWOOD KFC-W3005
This 4-ohm, 12" Woofer features an extremely strong yet lightweight Pearl-Mica Injection-Molded Polypropylene Cone, for accurate musical reproduction across its entire frequency range. The unique one-piece Tornado design makes the cone very stiff, which reduces distortion. The KFC-W3005 features 700-watt power handling and a frequency response of 25Hz to 800Hz. The extended, vented pole piece helps to maintain maximum magnetic energy while effectively dissipating heat. And a bumped yoke allows the voice coil a long, yet tightly-controlled range of movement - ideal for producing more sound with lower distortion.
SPEAKER BOX:
Dual 12" Subwoofer Enclosure for 82-82 Camaro, Firebird, Trans Am
$200 Firm
Price: $200 Firm
Description:
* Bridgeable
KENWOOD KFC-W3005
SPEAKER BOX:
$200 Firm
84 TA NV
09-06-2015 09:02 PM
